Question about Sewing Machines
How do I fix error E4 whe no thread is tangled?
The machine displays E4 which means that thread is tangled or the bobbin was stopped suddenly and there is no sign of either of those problems on my machine.
  • Anonymous Mar 12, 2014
    an eeprom error and an e4 error are stopping the machine from working
  • Sewing Machines Master
  • 7,365 Answers
Try changing the needle
rethread the machine top and bobbin
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
also possible that something has gone wrong with the computer
part of the sewing machine.
Posted on Nov 30, 2012
  • 55 Answers
SOURCE: bobbin thread tangling up
are you doing embroidery? if so turn off jump stitch cutting if possible. is the machine threaded correctly (pull needle thread out of machine and thread again with presser foot raised.
check for foreign matter in needle tension assembly. ensure there is sufficient needle thread tension.
the thread you see caught up underneath the fabric will be needle thread and indicates insufficient needle thread tension or something preventing the needle thread from being pulled up into the fabric (maybe a damaged bobbin case, or bobbin case position finger, or damaged needle plate hole).
goodluck,
scott
Posted on Jul 27, 2009
  • 9 Answers
SOURCE: burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Posted on Jul 17, 2009
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
  • 4 Answers
SOURCE: Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Posted on Sep 15, 2008
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
E4 message
contact singer customer service about the error code e4, the resistance could be a broken or damaged part.
Mar 22, 2014 | Singer Sewing Machines
Bobbin thread tangles
when this happens have you check to see if the thread has come off the thread take up lever?
Feb 09, 2012 | Brother CE5000 Computerized Sewing Machine
Hi I have a brand new machine just out of the box and I can't get the machine to sew. The thread from the bottom is bunching up and getting the machine to stop and code c4 displays.... maybe...
It is in your top threading. Totally rethread, with the presser foot up, new needle, (flat side faces to the rear of machine and the other one may have a burr on it), now with the presser foot still up, pull your top thread, it should feed smoothly, then put the presser foot down, pull thread again, it should barely move. This should seat your thread, I am not sure what c4 means but more than likely a threading error message, tangled thread etc. Good luck, next time state your brand and model.
Jan 27, 2011 | Sewing Machines
My bobbins sometimes don't wind right. The thread gets all tangled at the bottom of the bobbin instead of winding evenly. I'm sure it's user error because sometimes it works. Hoping you can help me figure...
when the thread is on the spool pin
1.guide the thread around the bobbin winder thread guide
2.insert the thread through the hole on the bobbin, threading from the inside to the outside
put the the bobbin spindle
3.push the bobbin winder spindle to the right (if you have a electronic machine the LED display
will show SP)
4.depress the foot control, when the bobbin is fully wound, stop it, & push the bobbin spindle to the left, cut the thread & remove it from the spindle
Nov 17, 2010 | Simplicity Sewing Machines
I keep getting an E6 error message - tangled thread. I think it's the bobbin thread that's getting tangled, and I can't figure out why, or how to fix it. Any ideas?
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Apr 02, 2010 | Brother BC-1000 Computerized Sewing...
Its like it is getting tangled in bobbin casing
loopy on bottom means upper threading or tension is wrong
Aug 10, 2009 | Brother XL-3510 Mechanical Sewing Machine
Lower bobbin thread tangling
You need to adjust the tention on you thread bobbin and on the needle....also, check to see if the needle is touching the plate or the foot.
I have had this problems too. Most of the time it is just a simple adjustment and cleaning.
Good Luck
Aug 02, 2009 | Sewing Machines
Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
Error message E4
All sewing machines are 'picky' about being threaded correctly. As you seem to understand. There is no shame in asking the seller for help.
Jan 23, 2018 | Singer CE350
Jammed thread.
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
182 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
