Question about Garden
Surface cleaner won't spin
It's a simple 2 arm set up that spins freely when the pressure washer is not hooked up, but I can hear a little metal on metal contact. Took it apart. Not much to it. Arms attach to a brass sleeve that slips over and spins a round a side port nozzle. The side port nozzle has two nylon or Teflon split rings (seals?) above and below the side ports. I was looking for something to grease. Maybe these rings are just worn out? Any ideas?
  • 1 more comment
  • Ted I Nov 30, 2012
    Should have mentioned water sprays out of the surface cleaner just fine, nothing wrong with the pressure washer. It's just the arm doesn't spin. It's a 15" EZ clean.
    Here is the picture
  • larry May 28, 2013
    Ted, I have the same exact problem. How did you fix it?
    Genius:
  • 1,669 Answers
I agree, the teflon rings appear to br the only things that wear (aside from the hole size which could wear from water abrasion, but unlikely). That would explain the metal to metal sound you hear at times because the seals prevent wobbling.
Posted on Jan 01, 2013
I purchased this unit a year ago and the spinner didn't last the season. The nylon bushings are the weak spot of the design. Researching I've found that they were originally made by Homelite; mine has the EZ Clean brand but also found the same design at Ryobi, Briggs & Stratton and now Generac ... As Homelite ended 10 years ago, the parts are no longer available and none of the others sell any of the parts. I just bought a new one from Generac and see that the design has changed so that there is now a proper bearing in the unit but the photos on-line and videos show the exact design of my EZ Clean as shown in the photo above. As it sits presently, the answer is to buy a new unit.
That means that there are literally thousands of units out there with minimal use that no longer function. The Bushings are quite easy to replace but they are not available anywhere. Maybe someone reading this has the ability to build and sell these bushings. Here are the specs. 1/8' wide x 3/8' ID and 11/16" OD There is sideways thrust so the sides of the bushings take the 'heat', get grooved and quit allowing the spinning effect so the tougher the material the better. The bushing ring has a sloped cut in it to allow it to be fit onto the solid end piece. If nobody steps up, maybe I'll do this...
Posted on Mar 29, 2017
Unscrew the two cleaning tips from the rotating arm with a seven-sixteenths wrench. Take a safety pin and clean out the tip openings from the inside. There is likely some small build up in the tips that is preventing the high-pressure water from getting out. You should be able to blow through the tips when cleaned.
Posted on Mar 29, 2016
I couldn't get my EZ Cleaner working for anything. The washing tubes wouldn't rotate whatsoever. I read where there is a filter in the connecting tip, and that it needs to be cleaned. I removed the filter with a screw driver and washed it in warm soapy water, and my EZ Cleaner is working good as new!
Posted on Apr 23, 2015
There is an inline screen filter inside the quick disconnect fitting. If clogged it will have insufficient pressure to make the arms spin.
Posted on Sep 06, 2013
  • Hector Sep 06, 2013
2 Suggested Answers
mxc2
  • 146 Answers
SOURCE: I have a 2600 Troy bilt pressure washer.When I start the pressure washer,no water comes out the nozzle and the nozzle is not clogged either.I took the nozzle/gun off and there still was'nt any wat
If when you take the High Pressure water hose off the pressure washer pump no water will come out they you may simple have the bypass valve stuck. You may need to just remove the outlet fitting and clean the bypass valve.
It would be helpful to know the model number of the pressure washer or the pump.
Posted on Mar 30, 2012
It seems like dirt in glasses and cups in the topack of the dishwasher, is there a kind of filter that should be cleaned??
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Daniel
May 18, 2011 | Dishwashers
Water is not going throught he top spray arm
Hi
Daniel
May 06, 2011 | KitchenAid Dishwashers
It seems like the dishes are not being rinsed on the top shelf.. the soap is getting baked on
Hi
Daniel
Apr 22, 2011 | Frigidaire Dishwashers
Dish washer not cleaning dishes in top rack
Hi
Jan 13, 2011 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
My Bosch washing machine has a drum that no longer turns. When the cycle reaches a point where the drum has to turn, I hear a series of clicks and the spin does not work at all. I took the back off and the...
Check you can move the drum freely by hand. 1. if its free - then check belt. 2. if it wines - check motor. 3. if does not move - you need to check for obstruction. hope this helps ....
Jan 07, 2011 | Bosch WFMC 3200 Front Load Washer
The upper arm is free spinning by hand, but from all indications, it is not spinning. Water is flowing freely and drain is excellent. Is the upper arm problem a major repair.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Jan 01, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
When the washer spins it makes a banging noise and the plastic around the tub shaves off
Thank you! We took our Duet 9150 apart and found that ALL THREE support arms were cracked. Same problem with shredded front tub also. My washer is a little over 7 years old. I called Whirlpool at the above number (you can't get "warranty service" but the parts service lady transferred me to the warranty dept). They were most helpful, and are shipping me both the metal tub AND the plastic which the metal destroyed, free of charge. Apparently your experience has shown them they have a problem with this...or I got a more helpful service agent!
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to replace Maytag Washer belt
I have a model sav2655aww maytag washer. And it needs a new belt but I dont know how to replace it! Can the pump be removed with out removeing the motor ? Also the tub keeps going off center whats with that ?
Sep 03, 2007 | Maytag SAV5710 Top Load Washer
Garden Logo
7,933 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
