I need knobs for maytag performa pgr 4410bdw
Maytag pgr4410
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
That model number is for a range.
Posted on Nov 30, 2012
Washer_tech
  • 164 Answers
SOURCE: MAYTAG PERFORMA is leaking
the bearing and seal are worn and leaking. if the machine is a good oe and the repair cost is reasonable, i would have it repaired. contact your local repairshop and determione the cost vs replacement of machine
Posted on Nov 17, 2007
SOURCE: maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Posted on May 03, 2008
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
TheMobilian
  • 8220 Answers
SOURCE: maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Retry
Posted on Dec 19, 2008
canbruce75
  • 1776 Answers
SOURCE: maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Posted on Aug 10, 2009
Maytag performa range oven top
If there are any screws around or in the burners, they have to be removed first. Once all the screws are removed, use a blade to loosed the burner. Then try turning again.
if you do get it open, lift just an inch or two to make sure you are not stretching any gas lines. They will break then you will need a new stove.
Oct 20, 2013 | Maytag PGR4410 Performa Gas Kitchen Range
How to remove the starter dial on a Maytag Performa Washing machine?
to remove the timer knob and dial,push the knob in and turn in a counterclockwise direction the knob will unscrew completly off then place a small screwdriver behind the dail and pop it off
Aug 06, 2011 | Maytag Washing Machines
Oven will not heat up all the time and not keep a constant temp.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 04, 2010 | Maytag PGR4410 Performa Gas Kitchen Range
I have a Maytag Performa electric dryer that won't start
you have an open thermal fuse.part no. la-1053,its kinda tough to install,i would recommend a qualified servicer
Mar 06, 2010 | Maytag Dryers
While cleaning oven the red wire fell off back left oven coil
Hello- If it just fell off, unplug power to oven, slightly pinch connector to make it tighter, and put back on coil. Let me know if this info helps- have more if needed. -Thanks -ED
Mar 03, 2010 | Maytag PGR4410 Performa Gas Kitchen Range
Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Nov 20, 2009 | Maytag PGR4410 Performa Gas Kitchen Range
Maytag Performa will not come on. Nothing happens
Burned Thermal Cut Off thermostat. at the bootom of heater housing, which means you have clogged vent as the root of your problem, probably it was taking long time to dry prior to your experiencing dryer not running.
Oct 31, 2009 | Washing Machines
Maytag PGR4410 Performa Gas Kitchen Range's clock display
you need to replace the control or get it it rebuilt check in your area for apliansse parts dealer have them send it away for rebuil it less expencive than a new one thanks gilles
Mar 15, 2009 | Kitchen Ranges
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
