Question about Hardware & Accessories
Vigoro 196-038 water timer how do I download a manual
SOURCE: vigoro water timer 196 036 water timer programming
every x days vs every x hrs. (once a day or every 12 hours)
Posted on Jun 29, 2009
SOURCE: I have two vigoro water timers and the connection
Unfortunately, the housing is glued together.
I took mine apart with a hammer and screwdriver only to find that the entire input, valve and output assembly is one piece.
Even if you find a new threaded ring to install, it seems unlikely success could be obtained in terms of replacement.
Bummer - why is everything built to end up in a landfill?
A meal threaded faucet inlet piece would have avoided my need to discard this unit.
Posted on Dec 13, 2009
SOURCE: I have 2 Vigoro 196-036
It comes out of the holes because the water goes in the holes. That might sound dumb but Vigoro designed these only to be in dry conditions, such as attached to the water line. I used them for sprinklers, but the water poured into the timer so bad it shorted it out in a week. I did find a vigoro timer with no holes and a sealed unit, and they work great. But I can't find them anymore.
Posted on Sep 28, 2010
SOURCE: vigoro 196-036 water timer manual
Here is theinstruction:1. Install the battery2.Use left attor to decrease and right arrow to increase numbers < > to set current time to nearest hour at the time, noting AM and PM3. Repeat above instructions to set "start time: to desired time for day to begin watering4. Use left and right arro <> buttons to set "how often" (watering frequency) to select an hour/day increment (8 hours=3 times per day, 2 days=every other day).5. Use left and right buttons < > to set "how long" (watering duration) to select a min. or hr increment.6Activate the watering program by pressing the Program on/off buttin: a horizontal bar will be displayed to signify the program is on. Press the program on/off again to disable the programTo avoid accidentally changing the current program, the arrow button will be "locked out" or inaccessible if "program on" is selected.To create a new program, press Program on/off if necessary to disable current program.
Posted on Jul 12, 2011
SOURCE: How do I get free
The vigoro duo delux might be same as Melnor 3100
Open following links:
http://www.melnor.com/instructions.php
http://www.melnor.com/instructions/3100_InstructionSheet.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Sep 03, 2011
Need to known how to set the timer do not have a manual we have the VIGORO deluxe water timer, they are about two years old.
I do not know how to set the timer, but can offer possible source for manual.
VIGORO timers can be same as Melnor:
Match up image with your timer and then download manual.
Water timers last 1 or 2 seasons. There is no repair for broken water timers.
Take a moment and rate answer for accuracy:
Sep 12, 2011 | Hardware & Accessories
How do I get free instruction for Water Timer Vigoro Duo- Deluxe Water timer # on front top lefte is 225-379 # on back is 0708
Sep 02, 2011 | Hardware & Accessories
I need instructions to the Vigoro- Duo Deluxe water timer 9 volt battery operated # on back is 0708..# on fromt top left is 225-379 Purchased at Home Depot I has5 to 6 cycles that can be programmed. I...
I have 2 Vigoro 196-036 watering timers. Why does water come out of the three holes near the battery compartment on one of them?
Aug 25, 2010 | Hardware & Accessories
My vigoro water timer i bought at home depot will not stay on manual off/om or on its program. I have installed the new 9 volt battery correctly since i can program ok but it shuts off in a short time...
I have a Vigoro 271-687 in which has worked well except when i change the batteries it wont reset and will not work do you have any solutions to this problem i really like this product just dont understand the prob
Jul 01, 2009 | Garden
Water is trickling out
No. Check to make sure the battery is good. If so, and you just purchased the timer, take it back.
Jun 24, 2009 | Garden
Vigoro water timer 196 036 water timer programming
Jun 18, 2009 | Hardware & Accessories
Vigoro water timer problems
I also had this problem and found that the water pressure was too high. I turned the water spicket down one a a half turns (yours may vary) and now it's working fine.
May 05, 2009 | Garden
Hardware & Accessories Logo
53 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
