My daughter has an ipod and we have downloaded tunes for her ipod.
can i download some of her songs on to my ilo mp3 player?
if so, how?
SOURCE: download music
go to www.limewire.com and download Limewire, its a file sharing application that is very good for searching and downloading MP3s. Download Java Runtime Environment (required for Limewire) go to http://www.java.com/en/download/manual.jsp and choose Windows (Offline Installation) to download. install Java Runtime Environment 1st then Limewire. run Limewire, connect and search audio files.
SOURCE: ilo mp3 player
The may be a problem with your boot files stored on your MP3 player, try formatting which may fix this problem.
First you go to "Start" - "My Computer"
- Now look for something called "Removable Disk" - That is your MP3
Player - Now right-click on it then click "Format" - Now allow format
to complete and this should have fixed the problem.
Now you've formatted put some songs on, then unplug then try.
Good luck. Hope my solution was helpful in someway.
SOURCE: How to download songs to the MP3 player
You cannot use the iTunes service to add the songs directly, because iTunes will only accept brand name iPods within the software itself.
You will need to use Windows Media Player to transfer the songs to your iLo player. All of the info about transferring songs in Windows Media Player can be found in the help files for Windows Media Player, but if you insist I will cut/paste/summarize the directions here for your perusal.
SOURCE: can't add songs
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
