Question about Whirlpool Duet GHW9150P Front Load Washer
Washer hung in draining process. Door will not unlock ,will not cut off . Can't get an error code to show
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Try cleaning the drain filter.
Posted on Nov 30, 2012
Lumpy816
  • 246 Answers
SOURCE: Whirpool duet washer has F02
You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump. Remove the #20 torx screw out of there too to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to turn counter clockwise. So after placing something underneath to catch the water left inside the machine ( a large bowl or bucket), turn the knob slowly counter clockwise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails, screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and you don't have any leaks. Put your panel back in and you're ready to go.
Posted on Jul 03, 2008
  • 1028 Answers
SOURCE: Washer stuck in Drain mode, flashes same time, can't unlock control or pause/stop
ck to see if any water in drum if so possible pump clogged ..remove bottom panel pump will have clean out port with large knob turn counterclockwise ..expect flood if water inside but can't be helped if washer is on pedistal open drawer and try setting bucket underneath and have towels handy..after cleaning reinstall port cover and try again..if no water in tub try unplugging hold power button down 20-30 secs and reconnect still have problem door can be unlocked by removing bottom panel and pulling small tab just below lock assembly from underneath
Posted on Aug 12, 2008
jmgldsmth
  • 1869 Answers
SOURCE: washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Posted on Apr 26, 2009
jsrock516
  • 5911 Answers
SOURCE: the door will not unlock. I have pressed pause /
"Fdl" is a door latch error code. This could be an indication of a door latch failure, or a defective relay on the Central Control Unit (CCU) that controls the door latch.
If you cannot get the door to open, there is a manual release you can use to open the door. The following link explains how to access:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
Make sure you UNPLUG the washer before servicig inside the unit. In some cases, using the manual release can return the washer to normal operation. However, if you still have problems there is a tech sheet inside the appliance that explains all the error codes and how to troubleshoot them. The test points required to diagnose the problem are also included. The tech sheet should be located directly behind the lower toe panel, or affixed to one of the interior cabinet walls. I would begin by checking all the interconnecting wire connectors between the CCU and door latch to ensure the connectors are all seated properly. Unplugging them and reseating each one can help.
If you determine the door latch to be the cause of the problem, the following link explains how to access and replace:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
Replacement parts (if required) can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancpartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Jan 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a whirlpool duet HT washer error code FH
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
I have a whirlpool duet model wfw70hebw. The washer stopped and I can't unlock the door. Have error code E1 F9
Try unplugging for 30 seconds and plug back in. See if you are able to reset the controls after that.
Jan 24, 2015 | Whirlpool Washing Machines
I have a Whirlpool Washer, Duet, 3 years old. I have had the washer stop withour being finished with the cycle. None of the controls would start it, the door was locked, and the error showed an F 21...
The F21 error code indicates a long drain time on this type of washer. The door will not unlock if the washer control detects that water is still in the tub. To manually unlock the washer door, take these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
  3. Carefully reach up through the bottom opening and pull the release tab on the bottom of the door lock assembly until it clicks. NOTE: Internal metal edges in the washer can be sharp. Protective gloves are recommended for this procedure.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open.
After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the filter out and clean it You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Here is a video to show you how it is done.
Oct 19, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire frfw3700lw0 drains but not spinning
Hello ctilton2001 - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 06, 2012 | Frigidaire FRFW3700LW Washer
LG Tromm washer, what does error code ''CL'' mean?
Hello there and welcome to fixya
THE cl is not a error code at all
it SIMPLY MEANS THAT THE CHILD LOCK FEATURE HAS BEEN ACTIVATED
not to dismiss the feature simply press and hold the wash and rinse buttons for a minimum of 5 seconds and release Your machine may be different so you may have to press a different series of buttons like if theree are 2 buttons with the unlock or lock picture on them or shows a child or something like this but it should be 2 buttons that are neded to unlock ok
Hope this is very helpful
Best regards Mike
Dec 15, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
Washer Flashing Error Code ND; door won't open after turning washer off
The ND error code means NO DRAIN. ,
The usually reason the door remains locked once the cycle is over is because the filter screen on the drain pump is blocked so not all the water could drain out...the door lock is tied into the pump and until the pump tells the control board that the wate r is out the door will not unlock. This tip i wrote will show ya how to take apart the washer to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 23, 2011 | Maytag MAH8700A Front Load Washer
Hi there i have the kenmore elite 45986 my washer is showing f21 i cannot seem to unlock the door i have checked the top drain it looks fine i called to have sears come out to check it out and they want...
Hello, welcome to FixYa.
Based on your post I understand you have a F21 problem with a Kenmore washer, the F21 error means an excessive drain time was detected as you may or may not already know...also the reason the door won't unlock.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time...including unlocking the door. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is)
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting FixYa for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony.
Regards,
Macmarkus :)
May 25, 2011 | Kenmore Elite 45986 Front Load Washer
Washer will not drain or stat new cycle, no error message
Apr 26, 2009 | Whirlpool Washing Machines
HI, this is a defective CCU(Central Control Unit). you must have it replaced asap. this will correct the error.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
