Question about Delphi 1986 - 1986 Oldsmobile Delta 88 Fuel Pump Strainer FS0002 Old
1986 olds 88 master cylinder leaking between plastic tank and pluncher housing can this be fixed without rebuliding complete cylinder only 6mo. old
No brakes on a 1986 honda accord
Did you get a good bleed with fluid coming out at all four wheels? If they bled good, and the pedal still goes to the floor, you need to check the brake master cylinder-it is probably shot with an internal leak. An internal leak will not let fluid pressure build up, so no brakes.
Did you keep the brake fluid reservoir from going dry while bleeding? If it went real low, air might have got back into the lines.
It is not uncommon when bleeding brakes on an older vehicle for the master cylinder to suddenly develop an internal leak and require replacement . Here's why: pushing the pedal all the way to the floor causes the master's piston to push in farther than ever before. The rubber cups then travel over a section of the cylinder not usually touched by the cups-old fluid can develop a crud there and when the piston pushes over it, the cups can get ruined. To avoid this when bleeding brakes, put a short piece of 2X4 wood block under the pedal. Then the pedal will not extend the master's piston beyond it's normal travel. Of course on a new master cylinder, you do not have to do this. A new master cylinder does require bench bleeding before installing, however, to ensure no air pockets develop from there.
Aug 24, 2014 | 1986 Honda Accord
1986 isuzu trooper clutch pedal went soft
some of these were manual clutch cable check adjustment of cable at firewall (bulkhead) and check for cracks around where cable goes through to inside cab common on old girls.
if hydraulic clutch system
check fluid in clutch master cylinder is it low?
it could have leaking slave cylinder on gear box bell housing or your clutch needs replacing, gear box out and replace clutch as a kit, pressure plate, clutch plate, thrust bearing (comes as kit) but dont forget to check and or replace the spigot bearing in the rear of the crank shaft when doing clutch kit.
Apr 01, 2014 | 1986 Isuzu Trooper
I have 94 Mazda mx-3 for the past month or so I've been having problems with my clutch and I notice a big wet stain on the floor mat and carpet I assume its the master cylinder or slave cylinder but I am...
It's leaking on the driver's side? That would be the master cylinder bolted onto the firewall. You will have to replace with a new or remanufactured clutch master cylinder. When the seals go out, the whole unit must be rebuilt. The store will give you a discount if you bring in your old one for exchange.
The clutch slave cylinder will be down on the transmission bell housing. Follow the small steel line from the master cylinder. It goes right to the slave cylinder.
Pretty easy to change out the master cylinder. Remove the steel line, unbolt unit from the firewall, then under the dash, there's a rod from the clutch pedal to the master cylinder. Just undo the retaining clip or pin holding the rod to the pedal. When the new unit is installed and filled with fluid, then you get to learn how to bleed the hydraulic clutch at the slave cylinder-the fun never stops.
Oct 31, 2013 | Cars & Trucks
95 olds 88 after an engine rebuild cylinders one and six fill with coolant. what else will cause this other than a busted head?
if this has a plastic intake these have a problem with the intakes warping allowing coolant into the combustion chamber.the only fix is to replace the intake manifold and gaskets.make sure the intake bolts are tight and torque to specs as if the bolts are loose/broken or not to torque then the intake can cause coolant to leak into the cylinder because the gasket is not sealing.
Oct 31, 2011 | 1995 Oldsmobile 88
My 1986 ford bronco 2 with a 2.9l v6 needed a brake master cylinder. i replaced it with a brand new one, and noticed that the base of the master cylinder, where it mounts to the brake booster, is leaking a...
You should not have any fluid leaking.
1.The new master cylinder may have been manufacturer incorrectly, but unlikely. 2.Did you reuse the fluid tank or did it come with a new one? If you re-installed old tank, seal may have not seated correctly. 3. Did you tighten the brake lines correctly? 4. It may be that there was fluid that leaking into the booster from the old cylinder, and that fluid is now coming out of the booster with use. One indication would be if the reservoir tank is showing any fluid drop. If it is the problem is 1,2, or 3 above. Let me know what you find out by leaving a comment.
I hope this helps. Feel free to comment or ask further questions.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Feb 09, 2011 | 1989 Ford Bronco II
How to replace old fluid for the clutch?
If your clutch will not engage when the piston is pushed in fully, you probably have air in the slave, the line , or the master cylinder. Place a piece of plastic and an old towel over the bike to catch any drips. Remove the top master cylinder cover and take an old, clean, lint free, cotton sock and gently soak up all the old brake fluid in the master reservoir. Place the sock into a used zip lock bag and discard. DO NOT touch the clutch/brake lever or you will draw air onto the system. Now fill the reservoir with DOT 3/4 brake fluid and bleed the slave cylinder. Warning: be careful not to spill DOT Brake fluid on your paint or plastic. Place a tube on the bleeder screw (slave cylinder) and loosen the bleeder screw. now pump the lever to push the air out of the system. Hint: if you do not have pressure in the master, loosen the brake hose banjo bolt enough to burp the air out of the master(2 or 3 pumps of the lever). Retighten the banjo bolt and bleed the rest of the system.
Bleeding the system should restore clutch performance. If you notice fluid leaking from the master or slave cylinder , replace the o-rings in the slave cylinder piston and rebuild the master cylinder. A master cylinder kit and slave cylinder o-rings are available at your local Honda dealer.
Feb 08, 2011 | 2001 Suzuki VL 1500 Intruder LC
I had someone change my brake pads without bleeding the brakes and now my warning light is on
Start at the master cylinder and bleed ,then the right rear,then the left rear,and right front,then the left front wheel.You should not have to bleed the brakes to install brake liners.
Jan 28, 2010 | 1993 Oldsmobile Cutlass Ciera
Brake valve leaking on front left side inside engine compartment in a 1994 Olds delta 88. Brake warning light
are you talking about the brake master cylinder, leaking fluid down the fire wall in front of the drivers position? if so ,it is probably running down the inside under the carpet as well.. no matter where its from brake leaks need fixing straight away. it is probably the brake master cyl. that is leaking and it is not a big job to replace it "YOUDOIT"
Nov 01, 2009 | 1994 Oldsmobile 88
Master cylinder leak.
40 to 80 bucks and a new master cylinder, replacement is faster and more reliable.
Sep 11, 2009 | 1988 Pontiac Firebird
Delphi 1986 - 1986 Oldsmobile Delta 88 Fuel Pump Strainer FS0002 Old Logo
18 people viewed this question
Top Delphi GPS Experts
Vernon Taylor
Are you a Delphi GPS Expert? Answer questions, earn points and help others
