What is the reset button for on my mpi monitor 411
Monitor MPI it flashes F 13 or 14 & smells, I had it cleaned 6 months ago
The codes are "E" Codes. an E13 is no fuel. E-14 means flame rod malfunction. Unplug the heater then reconnect, this will reset the heater. Try your red prime button. Could also be the fuel pump or your fuel source feed line isn't flowing fuel.
Feb 17, 2016 | Heating & Cooling
My light won't ignite on my mpi 441 monitor
this morning my heater, monitor 411, was running fine as always.
while it was running the power company came to work on a pole and turned the power off. it was down for about three hours. once power was restored it wouldn't come on.
the pilot light is off but I'm not sure if it's suppose to be while not running.I've tried priming it with three pumps, resetting by unplugging, beleeding the line, all don't work.
it's suppose to be 22f tonight so I could sure use some help.
oh, I have a manual but, of course, it doesn't cover the problem. I also called the company but got a voice mailbox...go figure.
somebody please help!
Dec 20, 2012 | Heating & Cooling
Where can I find a manual for MPI Monitor 40?
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 11, 2012 | Cars & Trucks
The sampo alphascan 411 has not picture the screen is black. Turns on but no picture.
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 11, 2010 | Sampo AlphaScan 411 Monitor
MPI 41 Keresene Monitor Heater LIft Pump over-primed?
I recently relocated monitor heater from living room to dining room and ran new line to heater. I have pressed the priming button located on right side and turn unit on, but all that happens is it will click on run for a cycle and burner never ignites and then turns itself off and burner indicator lights continue to blink on and off, I dont think it is getting proper fuel to unit. What do I need to do?
Jan 05, 2010 | Heating & Cooling
For some reason the 411 number now appears in the directory on the front of the phone screen. If I am not careful and do not shut the phone off completely when a call is ended, I will have a problem. I...
I have the same stupid problem. I haven't found a way to remove the 411 button but I have discovered that you can at least modify that button to another number and not have a ****-dial to 411 and incurring $2 / call (for me). Just use your stylus and tap and hold on the 411 button until a pop up mention comes up. You can then select the "edit speed dial" item. From here, just change the 411 to another number. not ideal as removing the button all together but at least it'll stop having the errant 411 calls which can rack up a bill.
Mar 30, 2009 | Palm Treo 750 Smartphone
E13 code, monitor 2400
You have an obstruction in your fuel line. Lint or rust or some other debris, either in your main fuel filter which I hope you have or in the small one in the fuel sump on the lower right hand side (the little square hole below the round finger hole for the reset button). The screen is cleanable with air or brakekleen or both. Or it might be that your Constant Level Valve is tripping or has tripped. Push the button in the round hole on the lower right hand one time quickly (don't hold it down or press it several times slowly) and you should hear the float drop. Fuel should resume flowing to the fuel sump at that time.
Dec 21, 2008 | Heating & Cooling
My tv has a sub channel on the screen an i cant take it off
Good Day, hectic 411;
Most TV's have a display button on the remote, try pushing said button. Try resetting TV or cabl;e/sat box for 3 to 5 minutes.
To reset unplug the device from the wall ac outlet, like rebooting your frozen computer.
Good Luck, big IRISH.
Aug 05, 2008 | Televison & Video
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
