Question about Canon PC-795 Copier
Canon PC-795 Need a copy of an service manual for a Canon PC-795 printer. My problem is a paper jam locate around the middle section of printer. Have look and look and there's no sign of any paper jam anywhere. My display panel has an blinking light and a squggle symbol that won't go away. Please help, any assistance will be appreciate. Thank you, Jesse J. Aguilar
  • jesse aguilar
    jesse aguilar Jun 08, 2007
    Your solution was very helpful. I look at sensor #2 and found the problem. It was not paper that cause the error, however a roach decide to start up her roach hotel at that location. Seems your good in what you do. Here is another problem on another printer.
    The printer is a HP DC 610. The problem is I have an error message that keeps re-occuring. Scanner failure. I have clean the scanner assembly and mirrors to see if this helps to clear the problem, however after 5 mintues or so. The error returns. I don't have enough money to take to a service tech, but I enjoy working on printers. My mechincal skills out skill my knowledge on this different types of printers, however I still enjoy working on them. Please e-mail @ jessejaguilar@yahoo.com with your solution.
    Thank you once again for a great solution,
    Jesse J. Aguilar
MY Canon PC 795 copier shuts down after five minutes , also has on going paper jams.
Posted on Oct 25, 2007
  • quail443 Oct 26, 2007
    Not only can Not find the sencor's I still can't figure out Why the machine cuts off after five minutes.   HELP.
  • 31 Answers
The blinking light with the squiggle symbol is the display for a paper jam. Not sure a service manual will help in this situation other than to be a guide as to where the paper sensors are located. There are usually 3 or 4 paper sensors located in Canon PC copiers. The first sensor will be located between the paper pick up assy and the vertical rollers*(*which are located behind the door on the right hand side used for clearing jams). The second sensor is located under the toner cartridge just before the registration rollers. The third sensor (if present)is located at the entrance of the fuser assy (some models of Canon copiers have omitted this sensor)The last sensor is located at the exit of the fuser assy. I would suggest that you remove the cassette, verify that a piece of paper has not been partially fed or ripped in the pick up assy. With cassette out of machine, open right hand door & verify that there is no jam and check that the flag or arm of the sensor moves freely. Remove the cartridge from machine and again verify there is no jam and the registration sensor arm moves freely. If there is a sensor in front of the fuser assy, verify that it also moves freely. Finally, check for a jam and sensor movement at the exit/fuser. After checking all sensors, unplug the machine and plug back in. (Do this without the cassette & cartridge installed but with all the covers closed) This should give you an install cartridge & cassette message. Install cartridge first. This should give you the install cassette message. Install cassette. If you still get a jam signal when plugging the machine in without the cartridge or cassette, the most likely cause is a blown sensor.(rare, but I have seen it.)If this happens you would then need the service manual to disassemble & repair. I'll keep an eye out for your reply! Good Luck!!!
Posted on Jun 07, 2007
  • Sonny Rimatello Feb 27, 2013
    I checked out jam section "c" found no trace of paper--sensors feel loose and free---I hvaen't feed paper into this printerfor a couple of months---I had to replace a magnatic clutch--before that it never show about a paper jam--this started to show up after I changed the clutch--can't get it to run-until I find out
    can't run the printer until I fix the jam problem
SOURCE:
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
I have a PC-795 the paper feed doesn't take the paper completely through the copier. I also have a finger screw that has come out and I can't find where it goes.
throw the finger screw away. packing for the mirrors. look at the exp lamp are the ends black. if so change the ex lamp. causes jam at regi. otherwise change the feed clutch
Nov 10, 2010 | Canon PC-795 Copier
Canon ir4570 always jam at fuser
To properly solve the jam, you would have to start taking apart the machine, take the fuser out and inspect the paper path, a service manual would be helpful as the machines paper path in most cases is very complex, there are alot of moving parts in the path.
there is possibly a small piece of paper in the path, stuck in a gear or something similar, or a part is out of place or there is something in the path that doesn't belong there.
Aug 15, 2010 | Canon Office Equipment & Supplies
Canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Apr 09, 2009 | Canon imageRUNNER 5570 Copier
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Jamming canon 795
Check the sensors(photointerrupter) & toggle hanging up
Nov 20, 2008 | Canon NP 6050 Copier
No paper jam and no copies
check the fixing ***'y
Aug 05, 2008 | Canon PC-795 Copier
Paper will not feed through machine
Brass screw is probably the chrome packing screw which normally sets in a hole near the front of the copier when you open the "**** shell" Paper pick up could need feed wheel. clean with fantastic or soap and water and see if it helps. Also on this model check your exposure lamp is it coming on, if not it may on flicker, On all these PC when the lamp goes bad the paper jams usually at turnaround. Good luck.
Jul 07, 2008 | Canon PC-795 Copier
PC-795 Shuts Off Mid Copy
clean big rubber paper feed roller above paper tray with a microfibercloth moistened with rubbing alcohol.
open copier look in lower section under the toner cartridge you will see a black foam roller wipe it off also and then try to use.
Jan 17, 2008 | Canon PC-795 Copier
Canon PC-795 Copier Logo
752 people viewed this question
Clive
Clive
old marine
old marine
