Question about Exercise & Fitness
My proform spacesaver 500 eliptical is making a clicking sound
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright
Link Arms
Unplug the power cord. Identify the pivot points where the lower handlebars and the footpad link arms connect at each side of the machine. Use a screwdriver to remove the inside and outside elbow covers at each connection. This will expose the pivots.
Put a box wrench on the lock nut at the inside of one pivot and loosen the bolt with an Allen wrench. Remove the bolt and check the assembly for nylon spacers or a bearing. If no spacer is found, proceed to the next step. Replace the nylon spacers, reassemble the connection and reattach the elbow covers. Repeat this at the opposite side of the machine.
Have an assistant hold a deep socket against the inside face of the pivot hub. Make sure the socket is large enough to allow the bearing to pop out. Insert the point of a flat screwdriver into the outside of the hub until it contacts the bearing. Tap the handle of the screwdriver with a hammer to remove the bearing. Repeat this to remove the bearing on the opposite side.
Hold each bearing next to one ear and turn the inner race with your finger. If you hear grinding noises or the bearing is rough, it must be replaced. Lubricate the bearing with lithium grease and a grease gun. Replace the bearing into the hub. Reattach the lower handlebars and footpad link arms and put the elbow covers on.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Posted on Nov 30, 2012
SOURCE: spacesaver 500 proformer
I suspect that the problem you are having is the problem I had when I purchased and assembled my Crosswalk 570. There was no power getting to the display, because there was no power getting to the circuit board. Following the manuals instructions (provided to you from the last person who posted) on page 22. The instructions are located in "The displays of the console do not function properly". Follow the steps on removing the motor hood. Now, verify that the AC neut is actually plugged in. If it is, MAKING SURE THE POWER CORD IS DISCONNECTED, check the rest of the connections. If you know how, get a multi-meter and physically check voltages with the power cord connected and the surge switch in the reset position. If you have voltage getting to the card, but no voltage leaving the card, then the card is probably bad and needs replaced. I hope this helps some. Remember, safety first; electricity can kill so be very careful.
Posted on Jun 11, 2009
bwinton
  • 83 Answers
SOURCE: The belt is slipping and making a squealing sound
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
ercupa190
  • 12223 Answers
SOURCE: need instructions for the proform eliptical
http://www.youtube.com/watch?v=He3CzByiqQk
http://www.youtube.com/watch?v=s3i1Cp3K5rc&feature=related
please see the video for proform eliptical.
sincerely.
e.cuadra
Posted on Nov 04, 2011
ercupa190
  • 12223 Answers
SOURCE: i need instructions for the proform eliptical
GO TO THE PAGE FOR PROFORM:
www.proform.com
they have videos, in you tube, check it please.
E.CUADRA
ercupa190
  • 12223 Answers
SOURCE: proform ZE9 eliptical screen blanked out evry thing else works
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of thepedals to the crank axles.
Posted on Nov 15, 2011
Motor belt is torn need to replace
see the video attached and proceed according. God bless you
Dec 02, 2013 | Proform Pro-Form PFTL11010 Power 1080...
Resistance not adjusting
Reading on HSN website, it is b/c this product is junk. Dozens and dozens of reviews stating the resistance is stuck and wont' change.
http://www.hsn.com/products/proform-smart-strider-spacesaver-elliptical/6647352?query=6647352&isSuggested=True
Jan 20, 2013 | Proform Smart Strider SpaceSaver...
Where do you plug in
Inside the right side battery compartment as you face the display as if you were using it.
Oct 24, 2012 | Proform Smart Strider SpaceSaver...
Need instructions for the proform eliptical machine
sincerely.
e.cuadra
Nov 03, 2011 | Exercise & Fitness
I need instructions for the proform eliptical machine
www.proform.com
E.CUADRA
Need a manual for proform 760 upright bike
To get an owners manual you can one of two things. First, go to
www.iconservice.com in the manuals link. There you can type your
model number/model name found on your machine usually on the bottom of bikes and ellipticals, and underneath the belt when the machine is in spacesaver position on treadmills. It will give you a PDF version that you can download for free. You can also call for a
hardcopy but it will cost around $20 with tax and shipping. The
number is 1-800-999-3756.
Aug 05, 2010 | Proform 650 Crosstrainer Treadmill
Spacesaver 500 proformer
user manuals are here http://www.iconservice.com/manuals.html
But with no display the troubleshooting may be difficult. I would venture that it is the console control board, but this is just a suggestion. Hope this helps
www.twincityrepair.com
Feb 04, 2009 | Proform 575 Crosstrainer Treadmill
Exercise & Fitness Logo
297 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
