Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
I have a stackable lse7800acl washer that the timer doesnt seem to move you can move it manually.Do i need a new timer?
Mine is maytag lse7800acl, the washer works fine if i move the timer manually
    Top Expert:
  • Maytag Master
  • 9,472 Answers
If the timer does not move then the timer motor is dead and it will need to be replaced. Here is the timer to order.
Posted on Nov 30, 2012
zeusfaber
  • 247 Answers
SOURCE: Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Posted on Feb 06, 2007
Illeagle
  • 525 Answers
SOURCE: Maytag LAT9706AAM Washer - Spin Cycle problems
If the timer is advancing but won't spin out, it is possible that the spin contacts inside the timer are faulty. A technician will normally isolate and confirm this diagnosis witth a special power cord hookup to the motor. From the way you describe your complaint, I feel that a timer would correct your problem.
Hope this advice is helpful!
Posted on May 27, 2008
SOURCE: Neptune stackable washer...
You put the detergent directly on top of the clothes.
Posted on Aug 04, 2008
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
SOURCE: mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Posted on Jun 11, 2009
My Frigidaire stackable washer/dryer is having a washer issue. It will agitate, but will not pump out the water. When I manually move the timer switch, it will not spin at all. I bought a new timer...
Spinning won't start until the water level is low enough. Yup, it sounds like a pump issue. Check to see if the pump is not blocked by something. Get to it, my man. At Warp speed!
Sep 13, 2013 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune Stackable washer/dryer will only wash one cycle at a time unless I manually move dial to next setting...also will not spin as of this morning. Model # MUE2000AYW thx
The timer motor is bad, you can order a new one at reliableparts.com , using your model number. For information on how to perform your repair please reply and i will be happy to help.
Thanks, Repairman45
Dec 19, 2010 | Maytag Washing Machines
Washer will not go into spin cycle but will spin if manually move the timer to another spin cycle
timer bust new timer or new machine, try getting someone to take a look at the timer first could be dirt stopping it from turning
Jun 30, 2009 | Maytag LAT3600A Top Load Washer
Dryer tries to start but drum wont turn
You can turn it by hand but make sure it is unplugged!!
Jun 28, 2009 | Maytag LSE7806A Top Load Stacked...
Need to know age of stackable
I purchased mine brand new in 1993.
May 27, 2009 | Maytag LSE7806A Top Load Stacked...
Cycle switch must be moved manually
what you gona need is a new timer knob.
copy n paste this web address;
http://www.partstore.com/Model/Maytag/Maytag/LAT8106AAE.aspx
"Was this helpful?"
May 08, 2009 | Maytag LAT3600A Top Load Washer
MAYTAG STACKABLE WASHER/DRYER FABRIC SOFTENER DISPENSER
check the lable on the softnef bottle it should tell you how much to use and how to delute it .
Jan 22, 2009 | Maytag LSE7806A Top Load Stacked...
My washer was working fine and now does not go through the cycles
the timer is not advancing by its self...defective timer replace..onthejob
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Cintrol panes lse7800acl
How did you gain access to the dryer belt.  My dryer is "clunking" when first started and stopped.  I think I need a blower wheel...any suggestions.
Jul 30, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
