Question about Honeywell Enviracaire Elite F300E-1019 Air Purifier
I have two Honeywell F300e air cleaner. The lights never come on even when the fan is blowing.. I hear a zap very rarely. If I bang on the side of the air duct to loosen particles I can here it zap. Here is my problem, when I take the cells out to clean, they are not hardly dirty. I have had the furnace people out twice and they said they are working but they said the neon lights are burned out. When i used to clean the cells on the air cleaner at my last house they would be full of dirt and the water would turn black. Now at this house the water is hardly dirty. I find it funny both neon lights on each furnace are burned out.. If I can get them to snap does that mean they are working even though the lights do not come on. I can not find a test button.
3 Suggested Answers
HVACjake
  • 22 Answers
SOURCE: f300e filter clicking
You may have a large particle of debris trapped or one of the cell plates is bent and too close to one another.
Posted on Jan 20, 2010
liteswink
  • 99 Answers
SOURCE: The Honeywell electronic air cleaner constantly
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Posted on May 25, 2010
Honeywell Enviracaire Elite 300 problem. Light is not on. Seems like no power to system. No snapping or noises. No obvious bent fins or broken wires
If it was wired to the return air it will have a flag switch to let it know the blower is on, sometimes the flag comes off and it wont operate, sometimes it is wired directly to the computer board on terminals EAC that stands for electronic air cleaner and the board turns the air cleaner on when the blower is running, if you have a meter you can check voltage in both places to see which one is the problem. let me know. thanks wally
Mar 11, 2011 | Honeywell Enviracaire Elite F300E-1019 Air...
Light not on in front of filter . Its a Honeywell Electronic air cleaner and I cant tell if its working because light is off.
Neon light on air cleaner does not come on
1. Make sure the furnace or air conditioner fan is running.
2. Make sure the access door is firmly closed.
3. Make sure the On-Off switch is in the On position.
4. On models without the Solid State Performance Indicator, if the electronic cell(s)
are wet, check again in two to three hours.
Link: Manual
May 15, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
F300e filter clicking
Jan 17, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Hi, I have a question about Honeywell F300E
You need to replace the power supply of the unit, Contact your heating and cooling contractor for service on the unit.
Oct 06, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell F300E not cleaning air.
A newly installed system should still be under the contractor's labor warranty. Call them and ask them to come out to check on the unit and explain what you wrote above. This should cost you nothing and is the best way to get to the bottom of the problem.
Nov 09, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
Filter not clicking or emitting clean air smell and dust is flowing like filter is not energized
MAKE SURE THAT YOUR CELL(S) ARE CLEAN ... CLOSELY INSPECT TO SEE THAT THERE ARE NO BROKEN IONIZING WIRES (THE SMAAL STAINLESS-STEEL WIRES THAT ARE BETWEEN THE COLLECTOR PLATES). MAKE SURE POWER GOING INTO UNIT TO IS "OFF"!!! ... NOT JUST THE SWITCH ON THE UNIT. THEN TRY THE FOLLOWING: THIS AIR-CLEANER THAS A AIR-FLOW SENSOR THAT SOMETIMES GETS CLOGGED ... IT IS INSIDE THE TOP CONTROL PANEL. THERE SHOULD BE A DIAGRAM UNDER THE CONTROL BOX COVER PLATE TO ASSIST YOU LOCATING THAT SENSOR. MAKE SURE IT IS CLEAN. THE HIGH-VOLTAGE TRANSFORMER BEING BAD USEUALLY WILL SMELL LIKE BURNT WIRING. AND WILL LOOK BURNT. MAKE SURE YOU SEE NO LOSE WIRES ... SOME TIMES THE SPARK-PLUG LOOKING WIRE GOING TO THE CELL(S) CAN BURN OFF ITS CONNECTOR. YOU CAN CHECK THE DOOR SAFETY SWITCH TO MAKE SURE IT IS MAKING CONTACT WHEN HANDLE IS PROPERLY CLOSED. GOOD LUCK ... HOPE YOU HERE THAT ZAPPING SOON ... BY THE WAY ... IF YOU GET A POWER LIT ON ... GIVE THE RETURN-AIR DUCT A SLIGHT BANG ... IF IT IS WORHING IT SHOULD SNAP CRACKLE AND POP FOR A FEW SECONDS. MAKE SURE YOU SEE NOTHING (HAIR?) LYING ACROSS THE PLATES OR IOMIZING WIRES ON EACH CELL IF YOURS HAS TWO. ELECTRIC AIR CLEANERS ARE ONLY GOOD WHEN THEY ARE KEPT CLEAN ... PET HAIR IS A CONSTANT MAITENCE PROBLEM AND CELLS SHOULD BE LEANED EVERY TWO WEEKS. FOR BEST PERFOMANCE. Joe_Rex 40+ years Hvac Contractor (retired)
Apr 29, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell Enviracaire Elite F300E-1019 Air Purifier Logo
52 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
