Question about Zebra S4M Thermal Label Printer
The font printing on my label is too small. How do i configure the font size to print the size that I want?
5 Suggested Answers
SOURCE: Zebra 105sl - printer does not print correct size
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
Posted on May 19, 2008
  • 6 Answers
SOURCE: Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Posted on Sep 25, 2008
  • 10 Answers
SOURCE: BAR CODE FONTS FOR LITTLE LABELS
Depends on what software you are using, but you can use any True Type Font for the human readable, and any propritry barcode font available as downlaods.
However these barcode fonts tend not to print very small, it is a matter of trial and error.
www.lancerlabels.co.uk
Posted on Feb 11, 2009
ozztech
  • 285 Answers
SOURCE: Zebra TLP 2824 Print Orientation
check on the driver, unther the advance tab, if some seting is tick.
if cant check the problem, install the driver again.
Posted on Nov 13, 2010
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
P Touch 1880 indicates MAX font size, but prints smaller sized label. If I print one word at a time, it prints in MAX size. If I print two or more words, it prints smaller font. Weird, new problem.
Sounds like you may have a maximum length set that keeps you from printing over a certain length of label and it is adjusting your font size to fit that length. You may need a manual to figure out how to reset the length.
Jan 14, 2011 | Brother P-Touch 1180 Label Printer
Font height is big in printed barcode. how can I adjust the size of the font?
check if the setting FORMAT CONVERT is with some numbers, please change for NONE.
This seting change the resolution from Printhead 200dpi or 300dpi or 150 dpi or none, none mins, if you have 200dpi printhead, print 200dpi resolution(small fonts). if have 300 dpi, print with 300 dpi resolution, if have 300 dpi(very small fonts) printhead, can print 150dpi(big fonts) if change this setting.
if ok, check the driver or your software.
Dec 05, 2010 | Zebra Z4Mplus Label Printer
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
I just changed the tape and the printer is printing small font
okay when you first start the machine up it tells you what sizes its going to print in you can change that by using F=1 orF+2 font type and font size hope this helps
Feb 03, 2010 | Brother PT-1000 Thermal Label Printer
Font size issue
Are you trying to print a two-line label?
If there are two lines of text, they are printed in size 1, regardeless the size you set.
Here is the procedure, described in the manual you can download from here:
http://welcome.solutions.brother.com/BSC/public/files/dlf/docp000113/pt1180ug01usen.pdf
Note:
• If there are two lines of text, they are printed with the SIZE1 setting applied,
regardless of the selected size setting.
• To quit the following procedure at any time without making any changes, press [BS/Clear] key.
1 Press [Function].
2 Press [<] and [>] until SIZE is displayed, and then press [Function] or [Backspace]. The current size setting appears in the display.
3 Press [<] and [>] and until the desired size setting is displayed.
4 Press [Function] (or [Backspace] ) to apply the selected size setting to the text.
Aug 06, 2009 | Brother P-Touch 1180 Label Printer
Can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Jan 04, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Zebra S4M Thermal Label Printer Logo
527 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
