Question about Toys
50cc chinese 2 stroke scooter wont run after it warms up
If cold, starts and idles fine. It will idle indefinitely, but once you take off it runs for about a city block and then dies and won't re-start. If it sits until completely cold, starts fine and same thing will happen when you try to ride it. I have installed a new carb, new plug (plug is not wet and perfectly tan), cleaned air cleaner, check vacuum valve on the tank. I'm stumped!
  • 10,291 Answers
It's possible there is excessive wear on the piston rings.
Posted on Aug 13, 2017
5 Suggested Answers
SOURCE: 50cc Two Stroke Scooter Engine - Poor Idle
I had the same problem- from out of nowhere the scooter started dying at every stop. I adjusted the idle screw to 2000 and it still idled up and down. I bought some injector cleaner but this will take a while to work (several tanks of gas) and then found this link- seems to be a very simple thing to do once you read this link. I hope it helps. --
Posted on May 19, 2009
BTK127
  • 9 Answers
SOURCE: engine dies after it warms up good.
in the bottom of your carburator there shoud be a little plastics pieceand usualy it gets in the way of the float i take them out of carburtors all the time and usually it block the float so it floods out the motor i just found a picture on google of something like it. try taking that out and put ur carb back together like thatee760e91.jpg
Posted on Sep 10, 2009
  • 43 Answers
SOURCE: I have a 150xcc scooter, water cooled,4 stroke
sometimes tight valve lash clearance will cause problems. Low compression?
Posted on Dec 31, 2009
SOURCE: Fuel Problem? I have an 8N that starts and
if you find the answer please e-mail me i have the same problem with my jubilee i've not been able to work on mine due to some fuel tank problems my e-mail is ky.hammer@hotmail.com thanks
Posted on Jul 05, 2010
TaoTao 50 will not idle
Hi, Misty you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the choke off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air-fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air-fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air-fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air-fuel mixture skrew can acquire without going past 3 full turns from the bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bought China scooter Won idle properly scooters
Tao Tao 50cc scooter idle problem fix
My chinese scooter wont idle or start Check the fuel petcock http://www.family-motorsports.net/GY6-50cc-150cc.pdf
TaoTao 49cc Scooter Parts
TaoTao ATM50 A1 Owner Manual
Mar 29, 2018 | Motorcycles
Eurotrac 125 City Lite shudders when cold
Hi, SJS and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa Juddering when pulling away slowly
Chinese Scooter Club View topic Clutch shudder
Welcome to Absolutely Scooters Supply
http://absolutelyscooters.net/pdf/CGEN_dawg_scooter_manual.pdf
Mar 19, 2018 | Motorcycles
50cc Scooter won't rev up, Keihin PD18J carb
my 50cc scooter will idle at first and rev very well but wont idle what can this be
Jul 08, 2012 | Motorcycles
Scooter starts but stalls after a few seconds. It has been stored for a few months.
Hi, Anonymous if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
1. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
2. Remove your air cleaner and clean and re-oil per Mfg. specifications.
3. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
4. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
5. Replace spark plug with a new one and check for spark.
For more information about your question please visit the website below. Good luck and have a nice day.2012 Tao Tao 50cc scooter BMW C1 scooter stall at idle after normal start FOUND IT
http://www.benelli-scooters.de/pdf/BA_Benelli_Velvet125.pdf
Benelli Velvet 150 2014 service manual DOWNLOAD FREE FULLMANUALS COM
May 20, 2010 | 2008 Benelli Velvet 150
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
Hard to start, and wont idle long.
Check the air cleaner and muffler for plugging first. Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. Turn the idle speed screw CW about 1/2 turn. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on and adjust the H needle CW til the engine speeds up somewhat, but is still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L needle CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops moving, but still allows the engine to keep running. Hope this helps!
May 10, 2010 | Garden
Yamaha Vino 50cc
take it to the junkyard it's a piece of ****!!
May 18, 2009 | Yamaha XT 660 Z Tenere Motorcycles
Mar 14, 2009 | Toys
Toys Logo
64 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
