Ademco Fbii 679s Siren Driver Logo
Otis Harris Posted on Nov 30, 2012
Schematic for fbii model 679s siren driver card
I need a schematic to fix a problem with the card the study channel do not work.
My alarm system siren is not working how can I fix this
Without knowing the make or model of the siren - and without knowing if it as in "all in one" unit with the siren, controller all in one - it is difficult to offer much help.
If the siren is a separate item, connected by a wire, then if it is 12v, you could try disconnecting it from the alarm controller and see if it works - then you would know if the siren is damaged or if it is the controller that drives it.
SOME sirens will be rotating fan, others will be 12v operated and some will actually be little more than a horn speaker - driven from an amplifier inside the control module.
Can you give us some more info please - make, model, what you have tried, does ANYTHING on it work (lights, beeps, flashes the indicators etc)?
Need schematics
You didn't mention the Brand or Model
Schematics seem to be a thing of the past
Good luck
Schematics for cjb100pd
Red is your positive, black is negative, both brown wires are to the speaker, and the yellow and green wire are for any emergency strobe lights you may want to hook up to it. P.S. if you wire up the brown wires and siren doesn't work make sure volume is turned up and try it again if it doesn't work then switch the brown wires around. Both toggle switches on the far right is to only turn the lights on. not the siren. Make sure the siren nob is turned all the way left thats off. The rest of the are just siren modes. The toggle switch all the way to the left. Push down horn comes on release it then horn goes off. Push up siren comes on for like 7-10 seconds and the goes off. Horn and your microphone always override any siren that may be on.
No sound card installed Xp automatically
you need to find what kind of soundcard you have and download then install the drivers for that sound card, open up the case if you have to and try to read what brand the card is and what model it is, then go online and get the drivers, that should fix your problem
5helpful
Programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
1helpful
03 chev silverado radio on but no sound
studying the radio schematics , i'm seeing a radio amp fuse under the hood ,in the main fuse box under hood , 30 amp , check that for starters , if the amp was out you would only lose sound , would like to get a fix ya vote , comment back because i have other thoughts on your schematics , and do you know if its the base model or premium sound , with or without cd ? , thanks .
5helpful
3answers
How to program a motorola gp328 vhf 2 way radio?
i have program kit and software i need program for emergency siren what i have to do
2helpful
I need a user manual for a Westinghouse security system - model XL4600SM
Here is the link to the Westinghouse XL-2T Security System Owners Manual -model #XL4600SM:
www.adt.com.mx/incjs/download.asp?glb_cod_nodo=20070118085923&hdd_nom_archivo=fbii-xl-2t-user.pdf
This link will automatically ask to download manual to your computer.
6242511.jpgDont forget to rate!!!
1helpful
3answers
Motorola Talkabout T5720 circuit schematic
We are a M dealer and the schematics for the TalkAbout line were never released to the dealer channel.
Top Ademco Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Ademco Home Security Expert? Answer questions, earn points and help others
