Question about GE JVM1850 1000 Watts Microwave Oven
My GE Microwave JVM1850 will not heat unless I put the vent fan on.
The unit runs and air comes out of the top vent but does not heat unless I put the vent fan on. Tried turning the fan on, starting the unit and then shutting the fan off a few seconds later and it will not heat. Will only heat while the vent fan is running.
  • antoo varkey Mar 02, 2013
    let me know problemsolved or not? how/ -anto
  • GE Master
  • 9,098 Answers
That's really odd. I don't believe I've heard of that one before.
I would suspect the problem is on your control board, which in most can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Posted on Dec 01, 2012
    New Friend:
Mine does the same thing, and so does my neighbor's. They are both GE that were installed when the homes were built back in 2011. I don't have the money to replace it, but my neighbor found out that it still works if you turn on the fan. it's been like this for about 4 months and still works, so obviously the magnetron isn't failing. and I read other posts about this same GE phenomenon that people replace everything from circuit board, to touch pad, to door latch and none of it made a difference. I think GE forgot to install the proper "fail system" all appliances have as soon as they are out of the two year warranty.
Posted on Jan 25, 2015
localwonder
  • 6784 Answers
SOURCE: microwave buttons not responding - microwave running constantly with door shut
OK, you will need to replace the magnetron and the touch pad as well. this will fix this issue.
Posted on May 29, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: buzz, plastic smell and no heat
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
Posted on Apr 11, 2007
SOURCE: New microwave; loud fan when heating items
Update: I took it back. After speaking to GE, they said that's just how it is, there is no way to silence or quiet it. I took it back and bought an LG. I love it!
Posted on Jul 01, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 02, 2007
  • 59 Answers
SOURCE: Heard a pop and now the unit does not heat
If the unit is not under warranty, I would probably buy a new one for a few reasons. First of all it sounds like it could be the magnetron, and replacing them can be expensive (after that you are going to keep replacing parts like the weakest link). Finally, they can be dangerous, so I would not recommend on working on them yourself. If you shop around on the Internet, you will find a replacement one for half the price. I know this is a negative answer, but it is probably the safest answer.
Posted on Apr 17, 2010
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
GE JVM1850 turns on but turn table doesn't rotate & light doesn't come on even though timer counts down. Doesn't heat & has low hum noise. Is it worth fixing or should I buy new? It is 8 yrs old.
if you like your micro fixe it, becouse even do new micros look better when it comes to work they suck they hardly last the warranty period thats if you are lucky...
Oct 19, 2013 | GE JVM1850 1000 Watts Microwave Oven
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
Buzzing sound... Turntable stopped. food heats up but uneven. No microwave fan when heating.. no light inside expensive fix?? Unit is 10 years old
If the microwave oven is 10 years old then it is time to consider a new unit, by your description it is going into cascade failure where different parts have stopped working, the buzzing sound is the magnetron warning you, it is about to fail. The fans job is to keep the magnetron cool while it is running.
Mar 08, 2011 | GE JVM1850 1000 Watts Microwave Oven
GE Microwave JVM1850 Does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jjs
Apr 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No lit LED, No panel control. Vent fan, running
We regularly repair these control panels for customers nationwide with our guaranteed $39.95 service.
Full details of our service are at http://www.microwavedisplay.com.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Aug 14, 2008 | GE JVM1850 1000 Watts Microwave Oven
Some buttons work, some don't.
The keypad may be bad. Most often they go bad due to moisture from cleaners being sprayed directly on them or steam from the cooktop when the vent fan is not used.
They can also go bad when the unit is stored in an unheated environment where there's a lot of air temperature change (hot during the day, cold at night, etc.)
It may also be some residue on the connections where the keypad plugs into the control board. Unplugging then replugging the keypad can sometimes clean them.
In other cases, a new keypad is needed.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 07, 2007 | GE JVM1850 1000 Watts Microwave Oven
Microwave does not heat.
The magnetron is the device that puts out the heat. In these units, that's the most common cause of a failure to heat. BUT - many of these units are subject to a campaign under which GE will replace the magnetron, stirrer and high voltage diode free. Check the bulletin to see if yours is covered: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.jpg Even if yours is not covered by the bulletin, it may have coverage of the magnetron. If you have questions, call GE Customer Relations at 1-800-386-1215 (8-6 ET)
May 03, 2007 | GE JVM1850 1000 Watts Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
556 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
