Question about Kobo eReader
Kobo screen 1/3 missing and frozen - Kobo eReader
How can I run the app mobile strike in the Kobo arcqphd without it turning into a frozen screen of charcoal???
If the OS of your KOBO is either IOS or Android, it will work otherwise it is not compatible.
Apr 16, 2017 | Tablets & eReaders
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
I tried to connect with talk talk for my kobo reader the password was not accepted my reader has now frozen?
my Kobo has a reset hole on the back, push a fine pin in there.
might do the trick.........worth a try
Oct 27, 2014 | Tablets & eReaders
Kobo mini screen images stuck in one corner
From what you say I would recommend a new unit
Aug 29, 2014 | Kobo Mini E-reader - White
Kobo screen frozen
If your kobo happens to have a frozen screen showing connected and charging plug it back into the device it was plugged into when you removed it. It will work. Trust me
Apr 08, 2014 | iPhone Apps
Kobo glo com help
Use your USB and computer to try and recover it. Follow the prompts on the screen.
Mar 12, 2014 | Computers & Internet
Kobo Glo ereader
try to reset it..... how to reset device would be written in you users manual
Jan 14, 2014 | KOBO, INC Kobo Glo
Screen is frozen device will not turn on
You can do a hard reset by holding down the round home button on the front, and the silver power button on the top, hold down both these buttons until you see an apple, then release both. Do this while unplugged
Feb 12, 2011 | Kobo eBooks by Kobo
Kobo eReader Logo
57 people viewed this question
Top Kobo Retail Supplies Experts
Electroboy
Electroboy
Are you a Kobo Retail Supply Expert? Answer questions, earn points and help others
