Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Power button flashes Orange every 5 seconds. I have to press the Power button 2,3 times in order for TV to start.
I have a Panasonic PT-50LC13..When I come home and turn the TV on..The power light Flashes GREEN as it supposed to, then after a couple of seconds in starts blinking ORANGE every 5 seconds. I have to press the Power button again 2, 3 times in order for power button to turn GREEN and TV to turn on. If TV has been working for couple of hours and I turn it OFF and then ON again it usually turns on without a problem. What is the problem? and can I fix it myself?? I'm a pretty handy guy. Thank you.. Please help
  • Suren Nov 30, 2012
    I've chenged lamps on this TV twice in 7 years. Usually when the lamp is bad, LED(LAMP) flashes and TV does not work. This time it's different (Lamp) LED is not flashing or lit red. Can it be because of the filters, can i clean them myself?
    This lamp has been in there for about a year and a half.
    Problem Solver:
  • 12 Answers
I'd be looking at voltage ratings for the three fans and the the blower fan located under the projector itself. Check the air filters there are two but hard to get to the one under the projector lense. Id say toss and replace they have alot of issues that's why panasonic quit making tvs
Posted on Feb 28, 2015
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Lamp could be bad or its a power supply problem
Posted on Dec 22, 2012
  • 108 Answers
SOURCE: Reset Time Problem on Panasonic TV (PT-50LC13)
Power on the set, listen for afaint buzzing sound as the set tries to fire up. If you do not here it then your lamp driver, or ballast is most likely faulty. Also make sure you have the door and all covers back in place and secure. And make sure you insatlled an orginal panasonic lamp because some generic will not work.
Posted on Jan 09, 2009
  • 59 Answers
SOURCE: panasonic projection TV power blinks in orange 5 times every 5 seconds
did you ck the lamp,  can you ck voltage to ballast should be around 300 volts
Posted on Oct 23, 2007
SOURCE: panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Posted on Nov 13, 2009
SOURCE: panasonic model# PT-50LC13
It very well could be the ballast. I unfortunately have this tv and keep extra bulbs because they go out about once a year. Last time when I replaced the bulb the tv blinked and the red lamp light flashed like it does when the bulb is bad. Ballast repair kit fixed it up. This is certainly a design issue but you'll get no help from Panasonic. If tv comes on the goes out after a while, clean the fan filter.
Posted on Mar 23, 2010
SOURCE: PanasonicPT-50LC13 blink codes
pretty sure this is a problem with one of the cooling fans.
Posted on Sep 13, 2010
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
I followed the instruction to install the new lamp and the power light green keep flashing when turn on then turn red. After that lamp light starting flashing every 5 second. Did you know what's the...
You have to reset the lamp timer. Turn the power back on. While pressing the VOL button on the projection display, hold down the PIP button on the remote control simultaneously for more than 5 seconds. The screen should show something that says "LAMP TIME WAS RESET TO 0. The lamp indicator should go out.
Mar 04, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do you remove the lamp
To replace lamp in Panasonic PT-50LC13 tv, please follow this...
1- Place your fingertips under the front cover and pull it from the projection display.
2- Loosen the lamp cover screw using a screwdriver.
3- Using a screwdriver, loosen the lamp unit screw.
4- Grasp the lamp unit handle and slowly pull the lamp unit from the projection display.
5- Put new lamp and fix things in reverse order.
Now need to reset lamp timer as follows,
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
When lamp timer will reset, tv sill show "lamp time was reset to 0" message.
Hope this info will help you.
Thanks.
Feb 25, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have replaced the lamp on my Panasonic PT-50LC13 but now it says I need to reset the lamp timer. How do I do this?
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds in
power on condition.
Sep 28, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
WORKS 3 MIN AND SHUTS OFF
If it is the power LED that is flashing orange 2times every five seconds , it suggests that the Lamp Cover was not reinstalled correctly. Remove and reinstall it
Jul 13, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Blank Screen - Panasonic PT-50LC13-K
Hey Ben, The TV is alerting you it is about time to change your light bulb, it will keep on doing this until the light bulb just dies.
Order your Bulb via On Line at any of the places, there are different prices, but average for the authentic one with the chasis included is @ 260.oo and only takes @ 5 days to get delivered. You can save up to 140.oo if you just order the pure light bulb, and go the extra mile changing it, I just explain someone how to about it, only takes you 30 mins. Good look, I hope I get help for my problem too.
Mar 16, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 shutting off
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic projection TV power blinks in orange 5 times every 5 seconds
Oct 23, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
241 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
