Question about Asko W6021 Front Load Washer
ASKO W6021 washing machine
I eave an overflow error message and the door won't open.
  • mikis281 Jan 11, 2009
    The "solution" did not work. The same error message came up when I reconnected the power and turned the machine on. The manual says to call a technician with this over flow error.
    Genius:
  • 1,550 Answers
Unplug the unit and plug back the unit and Use spin cycle in your machine to dry out the water from inside and then try to open the door .
Posted on Jan 11, 2009
  • SAM ANDERSON Jan 12, 2009
    Sorry for late response .
    You need to remove the pump and pull it apart to unwind the ribbon from around the
    pump impeller. You can see the emancipated pump with the impeller on the rotor shaft and the pump housing with the
    stator winding. Then you need to reassemble the pump, just gently hit on the back of the washer
    and check for proper operation.Your problem will be solved . This can be done by you if you have service manual with you or else call service people to do it .
    Thanks for using Fixya .
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
Door won't open
has your machine got a filter that is exsessable if so you need to undo it and empty the water,( before the door will not open with water in the drum its a safety device if the filter is not on the front of your machine you will need to find it and clean
Dec 10, 2011 | Asko W6021 Front Load Washer
My Asko W6021 won't start and the door won't open when buttons are pressed, although the power appears to be on (the red light comes on after power button has been pressed)..
Open the drain hatch at the bottom left of the machine. Open drain pump and check to make sure tat there are no foreign objects in drain pump. Object in the drain pump will prevent the unit from operating properly. If there is water still in the unit, you can use the drain hose to drain the washing machine. If you would like to open the door manually, disconnect power, remove screws holding red plastic handle in place. pull handle.
Mar 15, 2011 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
After a power serge caused by the local power authority we can not open the door to our ASKO W6021 - we have washing locked in the machine and want to take it out before the machine is taken away to be...
prise open the samll square door at the bottom left using the divider in the soap drawer. Once open extract the red loped handle and pull on it ot manually open the door.
Apr 03, 2009 | Asko W6021 Front Load Washer
Can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Oct 16, 2008 | Asko W6021 Front Load Washer
Asko front load washing machine
Try some WD40 on the door mech,(on door, ie.) And with switch off, close & open door 4 or 5 times.
May 09, 2008 | Asko W6021 Front Load Washer
Asko W6021 front load washer door stuck! If any one can help me please do thanks, Dwayne.
there is a little red loop that you can pull on to release the door manually. it is located behind the little door on the lower left of the machine. Pop that door open and take the phillips head screw out of the lever hen pull on it and the door will open.
Oct 24, 2006 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
