Question about Samsung LN52A550 LCD TV
I have a Samsung LN52A550P3FXZA Plasma. When I turn it on the picture is either black or the pixels are crazy and it makes a screeching sound. After turning it on and off a few times the picture finally works. Any ideas
lukster
  • 217 Answers
SOURCE: blackout problems
It could be the LVDS cable that is connected between the logic main board and the main board, sometimes this cable is too short and comes loose from one of the boards, it could also be a sign that the logic main is going out or the panel itself is shorting out
Posted on Feb 17, 2007
  • 4 Answers
SOURCE: Samsung LN-T4661F - When I turn the T.V. on, it
In this case, I believe it is the power supply board; more specifically the capacitors are failing. When you have the clicking problem and the long boot up times this has generally been the issue.
When you have video display problems such as shadows and lines that go away after warming up it is usually the LVDS cable and T CONN board going bad.
I had the shadow and line problem and replaced both the cable and board for $120 and that fixed my problem. Since I had the TV apart, I went ahead and replaced the capacitors so I wouldn't run into that later. You can find the parts numbers for the LNT4661F cable and board below. You can find links to you tube ( Part 1 & 2) to show how to replace the capacitors. Good luck.
Samsung A/S-T CON BOARD BN81-01312A
Samsung Lead Connector LVDS BN39-00883A
YouTube (Part 1) http://www.youtube.com/watch?v=Mm51C_RDIZE
YouTube (Part 2) http://www.youtube.com/watch?v=BNHHrgX_6cs
Posted on Dec 18, 2009
  • 21 Answers
SOURCE: Samsung 40inch LCD tv doesn't turn on for some
To all who are having power supply issues: Samsung is now acknowledging a problem with the faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Posted on Feb 22, 2010
  • 6 Answers
SOURCE: Have sound but no picture on Samsung plasma
It's a pretty common problem. The no picture but sound problem is usually the y sustain board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Posted on Feb 23, 2010
SOURCE: samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Posted on Mar 29, 2010
I have Samsung 58" Plasma model Pn58a550s1f that turns on and off with green lines and makes loud noises. Eventually fixes itself.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung Televison & Video
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
I bought a samsung 50" plasma 2 years ago while i was watching it the picture went off but the sound remains
The power supply for the pixel voltages has failed.
You can have a Samsung dealer replace it for you.
Dec 30, 2009 | Samsung HPN5039 50 in. Plasma HDTV
We have a Samsung Plasma TV we were watching this when the screen just went black we have the audio and all other functions but no picture? Can you help?
Each pixel of a plasma television contains a red, blue and green phosper. These immite a flourescent light individually to produce a nice bright picture. The odds of all of these pixels dying at the same time is so slight, it is likely to never happen before the return of Christ. So your black screen is another problem. There is an ultroviolet light emitting photo that causes these other photons to give off light. My diagnosis without actually inspecting your unit, is that your ultraviolet photon generator needs replacement. These usually last in an excess of ten years so while it may be a costly repair, if you otherwise are happy with your unit, you may want to repair it. Your only other option is to replace it.
Jun 28, 2009 | Samsung PS50Q97HDX 50 in. Plasma TV
Dead Pixels
You cannot fix the bad pixels, it simply means your screen has been damaged OR there was a manufacturing problem (faulty hardware).
The phone should still be under warranty, you need to send it in to be repaired.
Post back for further help (Additional info). Thank you for choosing Fixya!
Mar 29, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Red pixel cloud in plasma black
THIS IS THE START OF THE PLASMA GAS RUNNING OUT...PLASMA TVS ONLY LAST 4 TO 5 YEARS THE GAS JUST BURNS OUT....LCD TVS LAST ALOT LONGER UP TO 10 YEARS..
Dec 29, 2008 | Samsung PS42P2S 42 in. Plasma Television
Pro pixel LCD tv has sound but not picture, can see a flash when it is turned on but goes black
Refer to others I have posted to for this topic...defective lcd controller board.
Thanks
Josh
Oct 30, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
Samsung LN52A550 LCD TV Logo
98 people viewed this question
Jerry Greenberg
Jerry Greenberg
