Question about Goodman GMS807034ANA Heater
I have a goodman model gms80703ana the burner comes on and when the blower comes on the burner goes out.
    Genius:
  • Goodman Master
  • 1,033 Answers
This can be due to a dirty flame sensor or a high limit switch tripping. Clean the flame sensor first, this is a metal rod on the opposite side of the igniter, take steel wool and scrub it, then reinstall. If this does not work then the limit switch is tripping due to dirty filter, dirty blower wheel, weak blower motor. Aything that restricts airflow will cause the limit switch to trip.
Posted on Nov 30, 2012
  • john lloyd Jan 04, 2013
    how do I stop the limit switch from tripping.
    I put on a new flame sensor.
  • 189 Answers
SOURCE: pressure switch stuck open
It most likely is not stuck..... It is just doing its job. You "most likely" have over problems. To "properly" diagnos this problem you will need a manehelic gauge. You can have a wide variety of problems from as simple as a blocked or disconnected vacum hose to a lifetheatening problem.... a blocked flue pipe or a bad heatexchanger.
BE CAREFULL
GOOD LUCK!
Posted on Mar 08, 2009
  • 26 Answers
SOURCE: goodman furnace, inducer blower comes on, but
In the burner compartment opposite of the ignitor is the flame sensor. seems to be dirty. one screw holds it in. Remove and clean with a wire brush.
Posted on Nov 21, 2009
  • 102 Answers
SOURCE: i have a goodman gms80703ana that it will cycle
Does the inducer motor come on? If so doe the ignitor spark or glow bright red?
Posted on Dec 15, 2010
SOURCE: Inductor blower comes on and runs then the ignitor
I cleaned the sensor that was at the the right further most burner on my Goodman and it worked. got the answer to my problem here at fixya. My burner flame only lasted 5 secs before it shut off. Thanks to all who took the time to send me a response.
Posted on Oct 05, 2011
  • 3248 Answers
SOURCE: I have a goodman model gms80703ana led light blinks 3 times and will not come on.
3 blinks is the pressure switch not working
Posted on Nov 26, 2012
Testimonial: "Thanks. now it comes on the burner start and when the blower comes on it goes out."
Blower motor goes off
The ecm controlled motors are know for ecm failure. They do not like high speed(T5 terminal connection). Normally when the ecm is acting up the blower will not work at all. But I've seen em run for a bit then quit. The motor probably needs a new ecm
Oct 21, 2017 | Goodman Heating & Cooling
I have a goodman modle gms80703ana and at first the inducer fan would kick on in it's normal cycle then the furnace would shut off do to a pressure switch. Now the inducer fan only come on perodicaly...
First unplug your furnace to reset it then plug it back in with thermostat set to heat high enough to make the heat come on. As soon as the inducer motor came on you JUMP the 2 wires that go to pressure switch. Your igniter should come on and gas valve should open for heat. If the flame stay on the blower should come on after a few minutes. If it get to this point your problem could be pressure switch itself or inducer clogged.
Jan 30, 2014 | Goodman GMS807034ANA Heater
How to fix a pressure switch on a goodman Gms807034ana
Since the burners light this eliminates the pressure switch as the problem. Typically when the burners come on and shut off quickly a flame sensor, ground problem or the limit switch tripping are the main reasons. Since the flame sensor has been replaced, check the limit switch
Jan 04, 2013 | Goodman GMS80453ANA Open Flame Mid-Size...
Inductor blower comes on and runs then the ignitor glows flame comes up and burns for approx. 10-15 sec then goes out then fan comes on. Model number is PBKMLB12N0B0F I believe this is a goodman furnace.
Nov 13, 2010 | Goodman Heating & Cooling
I have a Goodman GMH950904CXAC. Thermostat calls for heat. It comes on and runs fine for about 5 minutes, then the circulator blower shuts off, but burners and draft blower still run. After another 15...
4 flashes is an overheat situation most likely caused by the blower not blowing. The blower relay controls the blower function. It is part of the circuit board. I suspect a new board will take care of the problem if you don't find a lose wire or something simple.
Feb 27, 2010 | Goodman Heating & Cooling
Having a problem with a goodman gas furnace, pilot starts and burners fire up, blower starts and burner goes out after like 5-10 seconds. Blower continues to run but only circulates cold air. burner does...
Sounds like the rollout is being tripped from the blower moving the falmes. i would have your heat exchanger checked for cracks or holes as this is usually the reason the blower moves the burner flames to tripp a rollout.
Feb 22, 2010 | Heating & Cooling
Goodman furnace, inducer blower comes on, but surface igniter does not turn red, then kind of goes thru a cycle then igniter gets red burners light and then go out for no reason. Blower motor comes on @...
Nov 21, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
323 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
