Question about Kanguru (u2-dvddup-154) Burner
How to open kanguru cd dvd duplicator case
Need to open case. Not sure what kind of security screw
2 Suggested Answers
  • 5386 Answers
SOURCE: where can i get a
How old is the duplicator? The company has two different manuals listed here: http://support.kanguru.com/index.php?action=file_library&folder=19 . The pdf version is for their current models: http://support.kanguru.com/download.php?FLIB=1&id=40 . A zip file contains the manuals for duplicators sold before 2009: http://support.kanguru.com/download.php?FLIB=1&id=42 . I suggest you try the manual for the older models first; the current models on the kanguru site have models numbers like U2-DVDDUPE-S1 .
I hope this helps.
Posted on Apr 25, 2011
My produplicator will not display the lcd screen
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electric extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Apr 30, 2011 | Tower Produplicator 5 SATA Burner DVD CD...
Where can i get a manual for the kanguru cd duplicator
I hope this helps.
Apr 25, 2011 | Kanguru (U2-DVDDUPE-D118) Burner
Hi, I'm having trouble with my Kanguru Solutions Duplicator. It says "Hard Drive Corrupted - error #233 (89)" I can still burn cds, but am wondering if there really is a problem. Thanks!
teacher357,
Given the error code you provided it looks like you have corrupt hard drive. You can try reformatting the hard drive or just replacing it.
There is a good chance that your data is corrupted on that drive in which case you will probably want to recover it. TestDisk is a powerful and free open source software tool kit that can help you recover lost, deleted, corrupt data off your bad hard drive. You can also try to slave your corrupt hard drive to another computer and try to access it that way.
I would try to recover the data and replace the bad hard drive with a new one. I would try www.newegg.com or www.tirgerdirect.com for some good deals on hard drives.
I really hope this helps and good luck!
Respectfully,
Adam04
Feb 28, 2011 | Kanguru HD Duplicator - hard drive...
What is the specification of this casing?
Introducing the NEW high-performance stand-alone CD/DVD duplicator systems. These duplicator systems are perfect for heavy production runs since there is no cooling period needed between runs. Beginners and advance users alike will find this system beneficial because of its ease of use speed accuracy and reliability. All it takes is a simple press of a button to get the duplication process started. Let the NEW high-performance stand-alone CD/DVD duplication systems serve as your solution for data backup music video duplications and much more!
  • Supports DVD+/-R DVD+/-RW DVD+/-R Dual Layer CD-R CD-RW blank media standards
  • Intelligent design automatically recognizes the source disc format
  • ?User friendly÷ controller utilizes familiar ?ESC÷ & ?ENT÷ keys with tactile feedback for easy navigation
  • System is upgradeable via firmware
  • Password protection modes prevent unauthorized usage
  • ?Dynamic÷ hard drive partition system saves HDD space by creating partitions according to the image size
  • Allows editing of image and hard drive partition file name
  • Fully stand-alone system - No computers needed!
Feb 10, 2011 | Sony 20X Burner/1 to 11, Black Casing...
How do I use a 7 disk duplicator tower? Model 52X65x52x
Hi you put your dvd or cd into the top copier,put however many blanks you want copied into the burners below, you dont have to use all 7 if you dont want to make sure the control panal on the front says copy press enter and thats it.
Jan 24, 2011 | Tower CD&DVD Duplicator Cases: 8 Bays...
I have a Condre CD duplicator. A couple of the drives will no longer recognize or duplicate CDs.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Dec 13, 2010 | Condre Computers & Internet
I have a Go-video duplicator P/N S52-3-H how may i obtain a manual
From Google .. Download Tower CD&DVD Duplicator 8 Bays Manual.. But You May Have to ente the Brand and Model good luck
Oct 07, 2010 | Tower CD&DVD Duplicator Cases: 8 Bays...
How to take out a sticker stuck inside the burner?
Open the computer case, disconnect the power and data cables from the drive and remove it from the case. How you do this will depend on the type of case your computer has. There may be screws on both sides of the drive, one side only, or no screws in a tool-less case where there will be some kind of release tabs so you can slide the drive out.
Once you have the drive out of the computer, there are four screws in the bottom that hold the drive together. Take those out, take off the top cover and you'll be able to get at whatever's stuck in the drive. Just be careful if the sticker is near the laser lens. If you poke too hard the pickup assembly can be damaged and you'll be replacing the drive.
In fact, with new drives only around $30, it might be easier and just as cost-effective simply to replace it right off.
Mar 10, 2010 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Kanguru (u2-dvddup-154) Burner Logo
89 people viewed this question
Top Kanguru Computers & Internet Experts
David Payne
David Payne
Are you a Kanguru Computer and Internet Expert? Answer questions, earn points and help others
