Question about Sony CFD G505 Boombox
My Sony CFDG505 Radio speckers stopped working
My BASS will work and submit the backround of a song but the speckers wont play the songs. It will turn on and say its playing and adjust volume, but no sound will be heard. How can I fix this?
  • 13 Answers
SOURCE: sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
Posted on May 06, 2009
SOURCE: The screan is totally frozen. Its stuck on a song.
did u try to turn it off?
Posted on Aug 03, 2009
  • 5 Answers
SOURCE: MY Sony CDX-R3000 will only play CD's. It will not
Try and reset it . disconnect battery under the hood for like 5 min and see what happens ..I had that radio and sometimes its just tempermental . take cd out and try it ? Sre any buttons stuck ? If that doesnt work then hopefully u like your cds at the volume they are at . Good luck
Posted on Oct 08, 2009
  • 5 Answers
SOURCE: how can i fix my sony Walkman sound??
Have you done a system reset and tried other headphones.
let me know
Posted on Dec 15, 2009
  • 5 Answers
SOURCE: Sony NWZ-E438F won't play music anymore.
Download http://esupport.sony.com/CA/perl/swu-download.pl?&upd_id=4015&os_id=7 This is Firmware 1.02
Posted on Jun 16, 2010
DIGITAL S METER READING TOO HIGH WHAT VR POT TO ADJUST
please follow this steps and fix it. GOD BLESS you
    • 1
Turn on all of the devices in your sound system. Turn off any auto-equalizers on your sound system to gain fullest control over frequencies. This switch might be found on the receiver or the equalizer itself.
    • 2
Play a test song on repeat. Choose a song with both extremely high and extremely low instruments so that you have a wide frequency range to listen for.
    • 3
Listen for any obvious distortions in the highs and lows of the songs. Lower the knob on your equalizer for any distorted frequencies until the distortion disappears. Try at first to find the highest setting possible without distortion.
    • 4
Adjust all frequency ranges in relation to each other to find a pleasing blend for your room, trying not to let any one frequency range dominate the others. Use the highest non-distorting settings found in Step 3 as maximum settings, but don't be afraid to lower a booming bass or a screeching flute that disrupts the overall blend of the music.
    • 5
Play a song from a different genre to test how the EQ works for different types of music. A hip hop song will have louder lows than a string quartet, for example, so make sure your bass frequencies sound crisp on both types of music.
Nov 07, 2013 | Magnum DeltaForce CB Radio
My amp won't play bass everything is hooked up
I have a similar problem with my 2012 civic, I hooked up my 1800w kenwood mp to my 2 12" w6s and 1 song plays and sounds great, the rest of my songs have no bass from the subs, just the car speakers sound normal so I dont know what the hell thats all about. I thought it was a wiring issue but I can play the one song all day and it sounds perfect so any suggestions? thanks in advance
Jan 29, 2012 | Sony Car Audio & Video
there is a format problem and formatting your appartus might help you
Mar 18, 2010 | Sony NWZ-E438F Digital Media Player
My music wont play anymore
try deleting a song and transfer the same song back to your ps3..the files may be damaged or sony could of released updates for it..
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
Radio turns on but wont play any sound
you may have blown the out put chip in the radio
May 21, 2009 | Jensen MP7610 CD Player
Sandisk 240m mp3 not playing
the radio and mp3 uses one audio amplifier, check if you have loaded your music with mp3 songs, if not load with mp3 songs. if songs used to play and just stopped playing, then follow these steps,
i does your display show song playing, if it does then your set is fault, and if it doent and display unsuppoted, load with mp3 songs.
ii if it was playing and just stopped, than take it to a tech, who can open it and check the change-over switch, or selector of that set.
iii the problem is to very big.
Mar 30, 2009 | SanDisk Sansa m240 MP3 Player
Radio still doesn't work after many tried... 98 Acura CL 3.0
it sound as if you have a short in you radio and if it was me i would get me a nice one with a cd and installation kit and that way you know what wire is which and you would be a lot happier so give that a try
Feb 06, 2009 | 1997 Acura CL
Problem in playing songs
bass and speak to loud turn music down
Mar 15, 2008 | Sony Ericsson Walkman W810i Cellular Phone
The walkman malfunctioned!!! please help!!!
Hi there, one of the problems you have is that there is not much you can access from via your phone, so often the easiest (although not speediest) solution is to re-upload the songs. Have you tried adding another song, playing it, and seeing if that song will play successfully? If it does, then I would suggest deleting the other songs, and uploading them to your phone again. If this is not possible (because you downloaded them straight from mobile network), upload them to a PC and see if the songs will play - if they do, save them to PC, reformat your card (my computer -> right click on card name -> format) and then put them back on your phone. Unfortunately if they wont play on PC either, the chances are they have been corrupted and you may have to contact your download source for a refund or new copies. If after trying these options you are still stuck, try a) a mates memory card in your phone, and b) your memory card in a mates phone. If a works and b doesnt, contact your memory card supplier. If b works and a doesnt, then contact your phone manufacturer. Hope this helps and isnt too confusing - Chris.
Aug 23, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony CFD G505 Boombox Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
