Question about HP Pavilion dv9000z Notebook
My laptop goes off when I unplug the cord from laptop!
  • HP Master
  • 32,281 Answers
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Nov 30, 2012
I force removd keyboard witht shutting down the PC n the laptop shutdown. Since then screen only shows a milli-seconds deem light. DVD rom light blinking. Fan not turning, only a blinkin green light.
This is a very common problem with windows laptops. This may or may not help but here goes. unplug power. then unplug battery from laptop. Now plug only power cord into laptop. Now turn on and start tapping the F2 fuction key. Once it goes into bios make sure that your boot order is cdrom first. Then save it and reboot with the bootable cd in the drive.
Also if now of this works unplugged Hard drive and see if it will boot up at all and into the bios setting. If you are not able to boot into the cmos make sure also that no cd is in the cdrom drive.
Take your time. Good Luck.
Aug 26, 2015 | Computers & Internet
Battery light on nothing else
Has there been ANY damage? Have you tried another Cord/Charger with the EXACT same power specs? Has the AC jack been damaged due to pulling on the cord while plugged it? Unplug, remove battery, plug in, try to reboot. Has it been overheating? Fan, vents, heatsink clean?
May 06, 2013 | IBM Lenovo ThinkPad T400 Notebook
My battery light is off.
The battery might be dead. Batteries only have a useful life and after that they have to be replaced.
Does your laptop work ok off the AC Adapter Power Cord? If so, your battery is dead and your power cord is good. If the laptop does not work off the Power Cord then either your Power Cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. In either case a good battery will not charge if the power cord or the DC Jack is bad.
Check your DC Power Jack which is where the power cord plugs into the compute. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Toshiba Satellite A105 Notebook
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
When I unplug the printer from my Dell Latitude D610 laptop, the battery icon appears on the bottom right hand corner instead of the "ON AC power" icon and the computers shut down due to a low battery....
Your AC power supply is not providing power - The printer is supplying your laptop with power via the usb port. When you unplug the printer, the laptop runs on battery until it goes dead. You will need another AC power supply,
Good Luck
Oct 03, 2010 | Dell Latitude D600 Notebook
My D600 does not respond when it is plugged in and charging. If I unplug it, it works fine. It charges completly. Any ideas?
Check that the light on the power block is on when it is unplugged from your system, if the light goes out when the cord is plugged into your laptop, you have a bad motherboard.
Nov 27, 2009 | Dell Latitude D600 Notebook
Cords,reciever, and headphones
The curly cord goes into the headphones themselves. It is for recharging the batteries. The power cord is obvious. The audio cord plugs into your computer, laptop, TV, radio, etc. To USE the head phones, unplug them from the curly cord. The sound goes from your laptop, etc. to the pillar-type thingy, from there it goes into the air where your headphones pick it up. I use mine while doing housework and tossing the ball outside with my dog. While my laptop sits in the office I can hear my audio book in the yard outside and all around the house. Just remember to plug the headphones back into the curly cord to recharge the battery. If / when the batteries die, you can use regular AA batteries...BUT DON"T PLUG THE CURLY CORD INTO "AA" BATTERIES or IT WILL BLOW UP!!
Nov 17, 2008 | RCA WHP150C Consumer Headphones
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
HP Pavilion dv9000z Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
