Question about Toys
Toy wooden castle, broken apart. Clean break. What is best adhesive to reattach?
  • 32,281 Answers
You could use Selleys 5 minute Araldite epoxy adhesive..
Posted on Nov 30, 2012
  • 16,147 Answers
Elmers wood glue with compression during curing. Note this is not white glue and it is sometimes called carpenters glue
Need to tear apart autogage plastic tachometer to fix the needle
Remove the gauge pod from the dash, get a heat gun and slowly warm the edged of the plastic face to relax the adhesive that holds the face to the pod. Carefully remove the face and place it face down on a clean surface. Carefully put the needle back on and do the reverse of the face removal to get the adhesive so it will reattach.
Sep 18, 2013 | Auto Meter - 2343 - Autogage Mechanical...
On my Maytag Gemini MER6772 Oven in the top oven a circular disc fell off from the right side of the top oven exposing the insulation behind the oven. There is no way to reattach the disc, screws, flaps...
If there is no visible clips or tabs to hold the plate in position, the best way to reattach the disc would be to stick it in place using a silicone adhesive. Make sure that the plate is clean and free of grease etc, as also the back plate of the stove. Apply the adhesive to the plate, fit in place and hold it there with masking tape or similar for about 24 hours until the the adhesive sets.
Jul 04, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Hi! We've just bought our son the playmobil castle 4866 and for some reason we can't seem to get it assembled correctly. When we follow the instructions, the walls, which are supposed to fit on either...
Here are instructions to building castle 4866,
http://www.playmofriends.com/forum/index.php?topic=5897.45
Also if you are having problems getting the gate to connect to the walls here is the fix
The red circles indicate that there is no proper fitting...after close inspection and going through the instructions again, I found out that I need to place the nortwestern corner, green circled, at a different system -x hole line.....
Dec 30, 2010 | Playmobil Toys
I need to reattach the door seal on my truck. what do i use to make it stay?
Hi Belangertodd,
Upholstery professionals use Contact Adhesive for this type of job. It can be bought on most hardware stores. 3M's High Performance Contact Adhesives are pretty good. Selleys Contact Adhesives are great too. Make sure both surfaces to be joined are clean and free from oil and debris. You smear the glue on both surfaces, let it tack dry before joining both surfaces. Letting it tack dry first is very important in order to get maximum adhesiveness. I hope this solves your problem. All the best to you. Good luck.
Dec 06, 2010 | 2005 Dodge Dakota
I just purchased the pink wooden imaginext castle at toys r us and it was the display model with no instructions, where can i find the assembly insructions for it?
hi
here ia link to the maual
http://service.mattel.com/instruction_sheets/T1976-0920.pdf
if not try searching here
http://service.mattel.com/us/instruction_sheets.aspx
Oct 23, 2010 | Fisher Price Toys
Wooden Blocks Toys problems
When first choosing a toy for a child, it is best to determine if the toy is age appropriate. The toy packaging usually has age recommendations. Companies take the time to research and test their toys before they put them out on the market. It is always best to monitor your child, especially a toddler, with any toy. Kids seem to have the knack for finding a weak spot with things whether they want to or not. Best rule of thumb is if a toy is smaller than the palm of your childs hand or if it can fit in their mouth, don't let them play with it. Children are special gifts. Let's protect them at all costs. Good luck.
Oct 26, 2009 | Heros Wooden Toys Building Blocks, 100...
Broken bow
That would be nearly impossible..
Your best bet is to find one on Ebay,, Yahoo oction or Criegslist..
Good luck ;o)
Aug 14, 2009 | Castle Toy Electronic Violin by
Swing along castle broken parts need to order My
Go to littletikes.com. They have a seciton to choose outdoor products and you can drill down to the swing and slide castle. All the replacement parts are available there.
Feb 19, 2009 | Little Tikes Swing Along Castle
Toys Logo
42 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
