Question about Breville BKC600XL Coffee Maker
Brewstation keeps asking me to add water - Breville BKC600XL Coffee Maker
Hamilton beach brewstation leaking
Sorry but if this company is like the BUNN corp there are not parts available to repair. they want to sell new only.
Nov 17, 2015 | Hamilton Beach BrewStation Deluxe 47474...
Hamilton beach brewstation will not brew
Can you define will not brew? Do you mean no water transfers from the holding tank to the brew carafe? Does coffee not heat up?
Apr 11, 2013 | Hamilton Beach BrewStation 47665
Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Dec 26, 2011 | Hamilton Beach BrewStation
Why does unit fill cup very slowly when the inside filter appears clean.
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
May 06, 2010 | Hamilton Beach BrewStation 47214 Coffee...
BrewStation® 12 Cup Coffeemaker With Timer * LEAKS
Contact customer service and have them send you a new gasket for the coffee tank. Doesn't cost much and adds a couple years or more to the life of your coffee maker.
Jul 29, 2009 | Hamilton Beach BrewStation 47214 Coffee...
The water does not shut off it just keeps running
this may not be the answer your looking for, but get a new on, you'll spend well over the 40 bucks that things cost trying to repair it!
Jun 25, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Hamilton Beach BrewStation 47224 Coffee maker
My coffeemaker makes the coffee just fine every morning, and we leave it on for 2-3 hours and then it turns off automatically , but later it leaks back to the water reservoir and then out the bottom all over my cabinet. What is wrong?
Oct 14, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Hamilton Beach Brew Station
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
BrewStation
Are you pouring the water into the water reservoir? My wife bought a BrewStation and the same thing happend to me the first time I used it. Of course, I did not have the directions. I filled the removable water/coffee tank, but did not transfer the water into the 'water' reservoir. The water does not drain by itself.
Works fine now.
Oct 12, 2007 | Hamilton Beach BrewStation 47214 Coffee...
Breville BKC600XL Coffee Maker Logo
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
