Question about Microwave Ovens
How do I change the light bulb in a JES 1451 ?
Owners manual does not say anything about changing light bulb inside microwave.
  • Microwave Ovens Master
  • 9,098 Answers
On this model, it's not meant to be a user serviceable part.
You would have to remove the outer cover, and then the light bulb is located on the air duct attached to the magnetron on the right side of the innards.
You can find helpful exploded views and order the bulb assembly from the Pros here.
Enter your full model number from the tag with suffix and no spaces.
See these help files on safety and disassembly first.
Posted on Dec 01, 2012
  • 37 Answers
SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Posted on Aug 03, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker Microwave
On these models, the oven must be pulled from the wall mount, then the outer cover must be removed. This is apparently to limit the manufacturer's liability. Removing the microwave from the wall is really a two-person job, since it is heavy and awkward. You don't want it to fall or slip, and the edges can be sharp. It helps a lot if you saved the original installation instructions. Once the oven is out of the wall, you can then access the lamp socket. These bulbs are special halogen types that must not be touched by bare hands, since skin oils will shorten their life. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Sep 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Ummmm I feel stupid
The manual is on the Emerson site at:
http://www.emersonradio.com/owners/MWO%20manual/MW8115SS.PDF
But it doesn't seem to mention a way for you to change the lamp.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Nov 19, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: how to change light bulb under microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
The first step is to unplug the oven before changing bulbs!
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
http://www.microwavedisplay.com
Posted on Apr 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
Sn797s panasonic microwave change light bulb
Probably located inside the cabinet which will have to be removed. Be aware of dangerous, even exposed voltage present with cabinet removed.
Dec 29, 2017 | LG LRMM1430 Microwave Oven
Change bulb inside ge pvm1870Sm2SS
You can download GE owner's manuals and installation instructions
here.
The manual will cover bulb replacement.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 17, 2012 | General Electric PVM1870SMSS Microwave...
I have a GE JES 1855 Microwave Oven, my light bulb burnt out there is no instructions telling you how to replace the bulb!
You have to take the out side cover off and there you will see how to change the bulb.
Jul 03, 2011 | Microwave Ovens
GE microwave JES 2251 SJ02 Light bulb that illuminates oven interior burnt out. Have correct replacement bulb (I think!). Can I remove oven cover and replace light bulb while keeping a good distance away...
sTEVE, THE CAPACITORS HOLD A CHARGE EVEN AFTER THE SYSTEM IS UNPLUGGED. A good rule of thumb would be to allow at least 48 hours for the capacitors to discharge before even getting nea them. Then, yes, you can replace the bulb. Thanks
Jan 27, 2011 | GE Microwave Ovens
I have a microwave JES 1142SMC which I need to repalce fuse but do not have manuel...Please help me as to how can I change the fuse. Please send me some instructions for fixing this.
There should be a "mini-manual" hidden inside the unit behind the control panel or attached to the inside of the outer cover.
It is very helpful when troubleshooting, & testing.
See this file and this file for more disassembly help.
You can find helpful exploded view diagrams and order parts by entering your full or base model number here.
Jun 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I change the light bulb INSIDE the microwave?
What you need to do is remove the case of the microwave and you should be able see the globe inside the unit, make sure you discharge the high voltage capacitor before touching anything else. After that is done, simply remove the globe. Good Luck.
Nov 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Change light on a ge convection microwave
If you can change the bulb there will be some screws on the outside at the back. On some models however you cannot replace the bulb.
Jun 06, 2009 | General Electric Microwave Oven
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Ummmm I feel stupid
Nov 18, 2007 | Microwave Ovens
How do you change the bulb
First, take off the cover and you will see the bulb. You must have the unit unplugged and do not touch anything else inside the unit after you take off the cover. Theres a capacitor in there that holds a big charge.. Change the bulb as you may have to go to the hardware store as it may not be a regular bulb Most are not. Good Luck
Jul 02, 2006 | LG LRM1250 Microwave Oven
Microwave Ovens Logo
175 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
