Question about Toshiba 42HPX95 42 in. Plasma Television
Toshiba 42hp95 plasma tv has now booting red light that stays on and a green light that flashes 3 times over and over
Tip
Toshiba 42HP95 VChip Reset
Toshiba 42HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Parental V-Chip parental lock?
Have you forgotten your VChip PIN, passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The VChip passcode will be reset and you can enter a new passcode if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
TOSHIBA MODEL #42HP95-BLINKING RED POWER LIGHT WONT STOP
Ur power inverter board is dead.
U need a new board.
Sep 07, 2009 | Toshiba 42HP95 Television
Toshiba 42HP95 TV turned itself off, red light blinking
has overheating issue try vacuming out the top and rear of tv. fan could be dead
Jun 02, 2009 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Front Panel Lock Reset
Toshiba 42HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Front Panel Lock?
Have you forgotten your Front Panel Lock PIN, passcode or password?
If you forget your Front Panel Lock passcode, you can unlock the front panel without entering your password:
  • The Front Panel Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Input Lock Reset
Toshiba 42HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Input Lock?
Have you forgotten your Input Lock PIN, passcode or password?
If you forget your Input Lock passcode, you can view the locked input without entering your password:
  • The Input Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
Toshiba 42HP95 Plasma tv
http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back
Worked for me, was ez, and I am a huge skeptic and not very "TV technical."
Dec 23, 2008 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
Tip
I hope that helps.
Tip
Toshiba 42HP95 Manual Download
Would you like to review the features of the Toshiba 42HP95 Plasma TV ?
Have you lost your Toshiba 42HP95 Plasma TV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 42HP95 Plasma TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 42HP95 Plasma TV documentation.
I hope that helps.
___________________________________________
Tip
I hope that helps.
Toshiba 42HPX95 42 in. Plasma Television Logo
113 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
