Question about Kenmore 62602 Electric Dryer
Dryer runs but doesn't dry
My dryer is doing the very same thing. does anyone have part numbers? thanks
    Problem Solver:
  • 18 Answers
Heater coil could be burnt out cost of coils vary between 35 and 70 dollars.
Posted on Jan 11, 2009
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Dryer heats up and tumbles but doesn't dry
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Jun 07, 2012 | Maytag Dryers
I have a Kenmore front loader - when I turn the knob to start the dryer, it make a noise like it wants to start but doesn't. I have tried to move the knob which indicates what drying time you want to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2011 | Dryers
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Will not dry in allowed time
you need top check and see if *** is heating up first.If it is check the back to see that the exhaust tube is connected and going outside where it should be. If there is no heat it could be many things. do you run it on the automatic cycle that stops when it is dry ;there is a sensor that tells it to stop and it may need a new sensor, It may need an element It may be at the breaker box if there is no heat it is running on 220 volt breaker which is 110v beside each other and if one of the 110 volt breakers has tripped then the dryer will run but not get hot, so check your breaker box before you call anyone to come and fix it.If this had helped please don't forget to click on the yes box on the way out, thank you and good luck!
Oct 09, 2010 | Kenmore Elite HE4 Electric Dryer
KENMOORE DRYER HEAVY DUTY MODEL 70 SERIES MODEL# 96574800 *Dryer starts and runs for approx 5 min. It becomes very hot and turns off. Can anyone help with the issue? Thank you.
If your dryer is STILL heating, but running excessively hot, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency, longer dry times and excessive heat:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to actually OVERHEAT. The Hi-Limit Thermostat and/or Thermal Cut-Out will trip once the internal dryer temperature exceeds the preset limit for which it is rated. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back and let me know. I hope you find this information helpful.
Oct 06, 2010 | Dryers
Dryer isnt heating up what could the issue be and how should i go about fixing it
Things to check, if these are all ok you will need to find a service company to come out and take a look unless you are really handy and have a good multimeter to do some testing. If so I would be happy to walk through some things to check.
- If it is an electric dryer check the fuses and or circuit breaker, one fuse or one leg of the breaker could be tripped and the motor still run.
- If it is a gas dryer make sure no one has accidentally turned the gas valve off to the dryer.
- Check the venting ( this would apply if you are getting some heat but not drying or taking too long to dry)
- If all these fail and you want more detailed troubleshooting send me the model number and your comfort level working with electricity and gas.
Thanks
Apr 18, 2010 | Kenmore 63942 Dryer
Heats up but not drying!!
The Vent is CLOGGED !!!!!!!!!!!!!!!!!!!!!!
TRUST ME
There is no other possible reason for the dryer taking a long time to dry other than vent restrictions or just poorly built duct.
DO NOT RUN THE DRYER WITH THE DOOR OPEN
Not only can it damage the dryer it can catch fire!!!
Jan 19, 2008 | Roper RES7646KQ Electric Dryer
Kenmore 62602 Electric Dryer Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
