Question about Arris Surfboard Extreme Docsis 3.0 Wireless-n Cable Modem And Gigabit Router
I don't have the security key number for my router. How can I get it without an ethernet cable?
It is a motorola router ssid number is Motorola-FE23F. I reset the router back to factory settings so that I could change the password and username and now it asks for the security key and I don't know it. What can I do.
  • 2,878 Answers
The key must be listed the configuration page in the Web Admin. 192.168.0.1 User admin Password motorola.
The manual is not as thorough as others so you need to do a little searching or create a new one. GL
http://www.motorola.com/staticfiles/Support/US-EN/Home-and-Office/Cable-Modems-and-Gateways/SBG6580-SURFboard-Wireless-Cable-Modem-Gateway/Documents/Static-Files/SURFboard_SBG6580_UserGuide.pdf
Posted on Nov 30, 2012
3 Suggested Answers
SOURCE: wep key
The username is "admin," and the password will be "motorola." These are the [case sensative] default settings. If it doesn't work, you may have changed them yourself and not remember, or your internet installer may have done it for you when they set-up your internet connection [I know the guy who came to my apartment tried to do that to mine]. In either event, if you don't remember what your settings are, just reset your modem. This will restore ALL factory defaults on the modem.
To reset your modem, just look at the back. An inch or so above the Ethenet jack is a tiny pinhole. To reset your modem, you need to stick something in there [A mechanical pencil will work,or a paperclip], and hold it for a full 30-seconds. All lights will go out, and then slowly all come back on, but keep on holding - do not let go until a full 30 seconds are up. After 30sec, let go - the lights will all go out again, and then slowly return. The modem is now restored to its factory defaults, so open up a browser page, access the modem [192.168.0.1] and try the default login ID & password. Good luck.
This is the address for the User Guide, if you need extra help :
http://broadband.motorola.com/consumers/products/SBG900/downloads/SBG900_User_Guide.pdf
Posted on Jan 19, 2008
  • 70 Answers
SOURCE: What if I don't know
Hold the reset button on the back of it for 20-30 seconds
Posted on May 07, 2011
Undo computer router security password
Assuming you mean for the Router itself
1) Make sure you have your LOG IN details for your internet account at your ISP. Make sure you have an Ethernet cable that you can run to your PC
2) Turn off the Router and look for the little 'factory reset' hole on the back (some have buttens rather than holes).
3) Push a paperclip into the hole (or hold down the button) & turn on the Router
This sets the Router back to 'factory standard. MOST Routers have the Factory password printed on a label (most of those without, you log in as 'admin' with password 'admin').
You have to use Ethernet cable because, after a Factory reset, the WiFi will be 'off'. You will have to re-enter the WiFI password (and anything else you changed form 'factory standard' such as the SSID)
Nov 12, 2012 | Computers & Internet
How do I find my WEP key?
ITS THE SERIAL NUMBER ON YOUR ROUTER, NOT SURE THE MAKER OF YOUR ROUTER, HAVE YOU TRIED OPENING YOUR BROWSER AND IN THE ADDRESS BAR JUST TYPE 192.168.1.1 AND IT SHOULD BRING UP YOUR ROUTER MENU, YOU CAN ALWAYS CHANGE THE CODE OR DISABLE IT, THERE SHOULD ALSO BE ALL THE INFO ON YOUR ROUTER SOMEWHERE IN THE MENU, WHOEVER SET THE ROUTER UP INITIALLY SHOULD HAVE BEEN IN THE MENU TO SET OR CHANGE THINGS. IF YOUR SETTING UP THE CONNECTION ON YOUR COMPUTER JUST CHOOSE YOU ARE CONNECTING TO A DSL THAT IS ALWAYS CONNECTED, AND IT SHOULD JUST AUTO CONNECT WITHOUT THE WEP KEY, BUT AS I SAID YOU CAN GO INTO THE MENU BY TYPING 192.168.1.1 IT SHOULD GIVE YOU ANY INFO YOU NEED.
Dec 31, 2011 | Computers & Internet
NETWORK SSID
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. Toconnect to your wireless router from the computer/laptop, configure thewireless card in your computer/laptop with the router's wireless settings ieSSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Dec 19, 2011 | Arris SURFboard SB5101 Cable Modem
Network ssid
Dec 19, 2011 | Arris SURFboard® SB5101 Cable Modem
I can not find SSID
My Friend,
You can follow these steps to find the wireless password.
>Connect your computer with a Ethernet cable to Slot number 1 on the router.(please don't connect to the internet port.) Just go to command prompt on your computer by typing CMD on RUN. >Type Ipconfig there and then you have to look for ipv4 address. >In this address search for the default gateway on the computer. >Type the address in the default gateway into the address bar on the browser. > Then this will ask you for the user name and password . Leave username blank and in password type admin. You will see the router set-up page . Go to the wireless tab and below that you will see wireless security tab. You can see the password under the security type such as Below security type as WEP OR WPA. Tere is a wireless key.
Hope this will help you.
Sep 09, 2011 | Linksys Wireless-G WRT54G Router
My security key does not work on new laptop, have excellent signal.Need help.
Use an Ethernet cable to connect your laptop to one of the LAN ports on the router, and reconfigure the router to set the SSID, the encryption-level, and the password. Then, you can disconnect the cable, and use your wireless network adapter.
Sep 01, 2010 | Arris Wireless G Broadband Router (wr850g)
I need to connect a new Apple Express wireless connector to my network, but I can't locate my password to my Motorola router, Model WR850GP, S/N 1461014278080930010. Can you help, please. Apple exerts say...
the default password is ADMIN or PASSWORD. TO reset to default, press the pinhole reset or unplug for a minute or so. This works in most cases. Good luck:)
Aug 22, 2010 | Motorola Computers & Internet
How to setup the pin number for my wireless
when you say pin number , do you mean the SSID number for security ? plug in the router using the ethernet cable , open up the browser, ie or firefox etc,goto the admin address, it may be 192,168,2,1or 192.168.0.1 etc
Jun 13, 2009 | Arris SURFboard SBG900 Wireless Router...
Wep key
Try admin for the username and motorola for the password.  The default SSID is Motorola.  Here is the pdf with all of this info.
http://broadband.motorola.com/consumers/products/SBG900/downloads/SBG900_Quick_Install%20_Guide.pdf
Apr 24, 2009 | Arris SURFboard® SB5101 Cable Modem
Got a Linksys cmpact wireless-g internet video camera can't get it to load without ethernet cable.
what is your wireless router? ]
may i know the wireless settings of that?
like the wireless network name (SSID) /
the channel that it is on /
the wireless security mode and the key, (well generally no need for the key, just the security mode).
Jul 26, 2008 | Cameras
Arris Surfboard Extreme Docsis 3.0 Wireless-n Cable Modem And Gigabit Router Logo
189 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
