Question about Lexmark Office Equipment & Supplies
Cartridge carrier lexmark z-22 cartridge carrier sticks on right end of track and makes bad noise
Strange as it may seem, I tried my printer again and it works perfectly now, weird for sure.
Posted on Jan 11, 2009
My Lexmark 7170 3-in-1 printer has an error message "left cartridge incorrect".
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Make Sure you have Inserted the Right Cartridges in the Right Place!
Good Luck!
Aug 04, 2011 | Lexmark X7170 All-In-One InkJet Printer
I changed the black and color ink cartridges on my Lexmark 2500 printer but both of the ink lights continue to blink off and on. I'm unable to get the printer to reset by disconnecting the printer and...
Make sure you are inserting the correct versions of cartridges for your model. Try to re-seat the cartridges by removing and re-inserting the cartridges in the carrier. The black cartridge goes in the left carrier while the color goes in the right. Also, make sure you are using genuine Lexmark cartridges.
Jun 27, 2011 | Lexmark X2500 All-In-One Printer
Lexmark 5470 says: incorrect right cartridge. I have insert new lexmark cartrdge no.35, after that anew cartridge lexmark no.33, and the printer says the same, even when the carrier is empty. I have...
Try to remove both black and color cartridges from the printer. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert both cartridges and make sure they are properly seated and secured in the carrier. Close the cover. If error continues to show on the display screen even if interchangeably insert your 35 or 33 cartridge, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
What are proceedures for replacing print cartridges for Lexmark X2600 ink jet printer?
Perhaps the Lexmark X2600 User's Guide will be able to help you. To download it, click on this link: http://www.lexmark.com/publications/pdfs/2007/2600/v7649663_en.pdf. Scroll to Removing used print cartridges, Page 45, for instructions on how to replace print cartridges.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps.
Jun 11, 2010 | Lexmark X2600 InkJet Printer
How to load ink catritridge #4&5
plz follow the steps below:
Step 1 Locate the "On" button located on the top right side of the Lexmark 2600 Series Printer Scanner. Turn the unit on by pressing and releasing the "On" button one time.
  • Step 2 Raise the scanner unit until it locks into place. Allow the print cartridge carrier to move to the loading position. Wait for the print cartridge carrier to stop moving.
  • Step 3 Locate the color print cartridge in the carrier on the right. Release the empty color print cartridge by pressing down on the cartridge carrier latch. Raise the cartridge carrier lid. Remove the empty color cartridge by pulling it straight up. Place the empty cartridge in the plastic bag and set aside for recycling.
  • Step 4 Remove the new color cartridge from its packaging. Remove the protective tape from the nozzle and connector on the back and bottom of the color cartridge. Dispose of the protective tape.
  • Step 5 Install the new color cartridge into the right cartridge carrier slot. Close the cartridge carrier lid. Press down on the cartridge carrier lid until it clicks into place.
  • Step 6 Raise the scanning unit slightly. Release the scanning unit support. Close the scanning unit.
  • If u find this post helpful, then plz vote it.
    Thanks
    Apr 27, 2010 | Lexmark X2600 InkJet Printer
    F4280 doesn't print; cartridgers stuck on right
    Turn the power off. Open the door. There should be a thin clear plastic strip with black tick marks on it that runs across in front of the metal bar that the print carriage rides on. Make sure that it is still there and hasn't been pulled off it's moorings on either end. This is how the printer keeps track of where the carriage is at any given time.
    Hood a finger over the edge of the print carriage and gently pull it out of its home position. You may need to slightly lift the front edge of the carriage and move it near the center of its range of motion.
    Close the door and turn on the printer.
    Mar 21, 2009 | HP DeskJet F4280 All In One Printer InkJet
    Clear Carrier Jam + Right Cartridge Incorrect
    aussie_jay09,
    If your printer is brand new, just out of the box, than repack the printer back in the box and march it right back to where you purchased it from. Your printer is classed under manufacturer criteria as DOA, which means dead on arrival. It is nothing you are doing, the printer is simply faulty and needs to be returned to your supplier for exchange. It happens sometimes and I am sorry you are on the receiving end.
    To be more technical about it, from what you are saying it sounds as though you have a faulty print mechinism. This is the central core part of the printer and I have seen this issue on many occasions.
    Gremlin11
    Dec 11, 2008 | Lexmark X4550 InkJet Printer
    Carrier jam on dell 924 printer??
    I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
    Hope this helps
    Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
    Lexmark X75 All In One printing problme
    Have you run print head alignment? or To clean the cartridge carrier contacts on the printer, do the following: 1. Power off the printer and remove it from the mains supply. 2. Open the printer lid so that you have access to the cartridges. 3. Pull gently on the ribbon cable connected to the carrier until the carrier is accessible. 4. Remove the cartridges. 5. Using a dry, clean cloth, wipe the contacts of the carrier gently from top to bottom. 6. Repeat Step 5 on the second carrier slot (where applicable). 7. Reinsert the cartridges and close the lid. 8. Reconnect the printer to the mains supply and turn on the printer again. Let me know what happens. Good Luck, Tim
    Mar 15, 2007 | Lexmark X75 All-In-One InkJet Printer
    32 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
