Question about Exercise & Fitness
TROUBLESHOOTING PO102 ON 3800CYL MOTOR - Exercise & Fitness
    Top Expert:
  • 12,223 Answers
1) See my personal TIPS for troubleshooting help
2) Test the input voltage motor, if there are the motor need repair
3) Test the output voltage boad, for input voltage motor, if there are NOT the board is faulty.
see the block diagram
God bless you
Posted on Nov 30, 2012
Outside Air Conditioner fan won't run
Outside Air conditioner fan , what brand (make) ? That's the condenser ! Probably the motor is no good ,there do go bad ,wear out etc.... In this video , check out the part shown , is this the same as yours ? Troubleshoot outside condenser fan ac hvac part High voltage , if not up on electrical troubleshooting suggest you have a HVAC guy come test it !
Aug 28, 2016 | Heating & Cooling
Noticed today the pool pump motor wasnot running, motor felt hot,
the most probable fault will be a failed start/run capacitor
next probable fault is something stuck in the impeller preventing it from turning or a rusted bearing at the pump end of the motor
Apr 20, 2016 | Pool & Spa
Motor not turning
You must RUN the software calibration for troubleshooting and fix it. Go under the HOOD for motor and follow the steps or your instru. manual for how to enter in the s. calibration
However you must test the power cord for open, breake with a DVOM
2) see the block diagram.
3) go to my personal TIPS for troubleshooting motor
God bless you
Nov 17, 2012 | Exercise & Fitness
Error code 91
I do not know what is the error code 91, but you must read the instruction manual section troubleshooting. Run the software calibration for diagnose and troubleshooting. If you do not have go to www. iconservice.com or www.fitness.manualsonline.com
However this codes can be relationed with 2 alternatives:
1) elevation motor 2) Main motor.
a) adjust the speed sensor, clean, and tight the wires connector.
b) measure the input voltage motor, if there are the motor need repair.
c) measure the output voltage board, for input voltage motor, if there are NOT, the board is faulty.
SEE The block diagram. God bless you
May 26, 2012 | Exercise & Fitness
Where are located the blower motor resistor in one VW transporter 2.5 T5 2005?
The resistor is locatedright by the blower motor itself . --------- Also click this link below for car problem troubleshooting:--- http://schematicsdiagram.blogspot.com/2011/06/car-troubleshooting-guide.html ----------- Thanks.
Jun 27, 2011 | 2004 Volkswagen Eurovan
I am having problem getting my dryer to start. I turn it on and everything lights but but when I press start button it just beeps at me.
These symptoms characterize a problem with a blown thermal fuse located on the blower housing. It is wired in series with the motor and cuts power to the motor when it blows and the motor cannot run. Dryer function works when the motor is not running. Click on the link below for the detailed procedure in troubleshooting this kind of dryer problem.
Troubleshooting Whirlpool and Kenmore Dryers Not Starting
Mar 30, 2011 | Dryers
Dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
What is Lr error code
I’ll post this in reference to Troubleshooting an Lr error code associated to the FAV6800AW/FAV9800AW.
Lr = Locked Rotor error “”Locked Rotor: The machine has repeatedly tried to turn the motor””. This could be caused by faulty Motor Controller, Motor, Control Board or issues in communication of the Control Board to the Motor Controller/Motor via the wiring harness. Here are a couple of links to support troubleshooting efforts; Service Manual for reference. Sears Parts Direct for parts reference.
I’m an owner like you and I worked vai e-mail a while back with an owner that was experiencing a constant “Lr” error code on their FAV6800AW. That person ended up replacing the Motor Controller after replacing the motor that did not fix the issue. You could try the Motor Control Board Output Test on page 15 and others checks on page 16 of the SM.
Unfortunately the SM gives very little support in troubleshooting this issue. If you decide to troubleshoot first pull the plug on the 120VAC to the machine. You could try reseating the plug on the motor and the plugs going into the Motor Controller. This could be a hard one to troubleshoot without a known good Motor Controller, Motor and Control Board to substitute. If you are a DIY’er and have an DVM you could try the troubleshooting steps on page 15&16 of the SM.
If it were my issue and the SM troubleshooting steps did not help fault isolate the failed component I would pick up a Motor Controller from ebay (90 day warranty type) and try that first with my fingers crossed, not the way I like to troubleshoot. The Motor and Control Board are under warranty by Maytag for 5 years from DOP. I believe the Motor Control Board is under warranty for only 2 years. Maytag Customer Service contact info is at the back of the SM. Good Luck.
Jun 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I am looking for a place to plug in an extra plug under dash( blower motor does not run)
If its anything like a 95 model, that unused plug near the blower motor is used when setting the timing on the vehicle. It removes the ignition advance from the distributor. I would be careful about experimenting like that.
To troubleshoot your blower motor, go buy a cheap test light and unplug your motor plug. Connect the test light. Turn on your motor switch. If it lights when connected properly, the motor is bad. If not you have other issues. Could be a relay or resistor module. Just takes a little more troubleshooting.
Mar 03, 2009 | 1999 Chevrolet Blazer
Exercise & Fitness Logo
46 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
