Question about Drills
CANT FIND WHERE PART 130 GOES ON A DEWALT DCH213 ROTARY HAMMER DRILL
joboo1
  • 257 Answers
SOURCE: 24v dewalt dw005 was using my drill in chisel
Hi, You should take it back while the warranty is still fully intact as this is a problem and will not resolve itself.
Good Luck to you, this should Fixya!
Posted on Mar 23, 2009
  • 5 Answers
SOURCE: rotary hammer won't rotate, hammers very good
If tool hammers brushes still good. Motor runs hammer action.
Take hammer/ drill switch lever off by removing small plastic plug in center with small screw driver.remove indicator handle off by removing #8 torx screw and lightly pry off. There is a pin and spring that lock tool into hammer or drill.Check for broken spring or binding spring and pin.If binding , clean and grease.
Posted on Jul 08, 2009
comax
  • 154 Answers
SOURCE: Bosch rotary hammer (model # 11230EVS) drill will not rotate
There is a clutch in the main spur wheel of the unit. These sometime begin to slip, on rare occasions they will slip to the point where the drill will not rotate. If you are interested the part number for this clutch is 1617000817.
Posted on Aug 06, 2009
SOURCE: Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Posted on Oct 11, 2009
deme-tri
  • 90 Answers
SOURCE: I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
Posted on Dec 03, 2009
My dewalt drill won't switch to hammer
I had the same problem. You need to manipulate either the speed or the torgue. In some cases both. Sometimes the drill/hammer feature gets stuck in between the two an this is the only way to fix it unless taking it apart but I wouldn't do that yourself. Best to take it back to the dealer or service shop
Feb 28, 2013 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
I have the chance of a cheap D25303K dewalt 230 volt drill. does it have a chisel rotation stop (percussion only) feature ?
Go to the Dewalt service website at http://servicenet.dewalt.com, put the model number in the parts search box and you'll be able to view or download the parts breakdown and owner's manual. By the manual that model does have three modes; a hammer only, drill only and hammer/drill.
May 28, 2012 | Dewalt D25303K Electric rotary hammers
How do you get the chuck off the drill as i need to replace it
Press down the sleeve and remove 136 by force, its just rubber, you are going to hurt it. Then take a pick (sometimes 2) and get underneath 130 being careful not to overbend it. Once you have 130 off the tool, 135 will slide off, exposing 134 and 133. press 133 down and with a magnet, remove 134. All that is left is 132 which slides right off.
Nov 22, 2010 | Dewalt 1" Sds Rotary Hammer Drill D25113 8...
D25600 does nothing when i pull the trigger
take it to a repair shop.could be broken wire in lead,could be burnt out armature,could be crook trigger switch,try a new plug on the lead
Jul 05, 2010 | Dewalt D25600K Electric Rotary Hammer
The hammer action on my 24 v sds cordless drill only seems to work at times and is overly noisey,any ideas what the problem is
Motor windings may be bad. All Dewalt tools can normally be rebuilt @ Dewalt store for $99.00. I have had 6 tools rebuilt @ that standard price. Dewalt site can give you nearest store. Batteries worn out?
Oct 08, 2009 | Dewalt DW005K Rotary Hammer
Drill will rotate but will not hammer under load
most of these types of tools have a manual switch it will be located on the body of the drill just behind the chuck on top or bottom or oposit the grip handle. some models have 2 switches.you want to make sure the switch points to the picture that shows a hammer and drill together.also rember it needs to have down pressure for the hammer part to activate.
May 19, 2009 | Dewalt 1 9/16" Rotary Hammer Drill D25551k
24v dewalt dw005 was using my drill in chisel position for about 25 mins when changed back to rotary hammer it sruggled to get going and was sticking in chisel the lever was fully to rotary.will this...
Mar 23, 2009 | Dewalt DW005K Rotary Hammer
Drills Logo
76 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
