Question about T-Mobile Wing™ Smartphone
Tmobile wing frozen
My wing wont get past the 2nd screen wich displays(windows mobile)then restarts its self and repeats same process over and over again
  • 6 more comments
  • berrykaren59 Jan 16, 2009
    my tmobile wing won't go pass the screen after the windows screen
  • atulkamboj Feb 11, 2009
    I have the same problem :(
  • ladybug1983 Feb 12, 2009
    I am having the same problem. My phone was going really slow and the screen was starting to freeze so I restarted it. Then it just started to recycle the screen, I have taken the battery out mutiple times. I am going to try keeping the battery out for about 30 mins and see what happens.
  • Anonymous Feb 15, 2009
    i have the same problem. i also tried to remove the battery for awhile, put it back in and power it on but no luck. someone help!
  • Anonymous Feb 20, 2009
    my wing does not go passed the green screen that reads "Windows Mobile". Help! Someone told me I need to get the software from tmobile but can't find it...
  • Anonymous Mar 03, 2009
    My Wing also continues to recycle the screen and won't get pass the green T-Mobile screen, and it won't shut off. I have taken the battery out, but same problem. This only started about 4 days ago, before that it was working.
  • gerelle0203 Mar 11, 2009
    My T-moile wing scren said: "Tap the screen to set up your windows based device" But, it wont change at all please HELP!
  • jamesgordon7 May 23, 2009
    my phone will not get past the green windows mobile screen. if I put the mem card in then it reboots over and over. if I take it out and restart it... it just sticks on the windows mobile screen.... OMG! I can't wait till my new phone comes in the mail. Its been stuck like this for over 2 weeks now! Word of advise to anyone thinking of buying a wing.... DON'T DO IT!! this is not the only problem i have had with the phone. OVER IT!
  • 4 Answers
Turn off your mobile and then pull out the storage card, Restart your device, it should work now !!!
Posted on Mar 05, 2009
    Problem Solver:
  • 5 Answers
You need to do a hard reset which will get rid of everything after tht you must wait an set your device up all over again to do a hard reset all at the same time first press left soft key then right soft ket then the soft reset on the side after tht let the soft reset go an continue holding the two soft keys til the hard reset function pops up then let go an press the green send button to finish it all!!
Posted on Jun 18, 2009
Try disconnecting external power from charger or USB sync cable. Press reset button and quickly remove battery before unit has chance to recycle. Then remove any installed memory card.
Now hold down reset button and power on button for 15 seconds, then release reset button followed 5 seconds later release power on button. Unit should reset itself and reboot. I was able to get past continuous rebooting cycle, and phone began to function normally, albeit without memory storage card.
Have not attempted to reinstall memory storage card.
Posted on Jun 12, 2009
I also had the same problem a month or so ago... You need to download a new rom update from HTC on the TMobile site, it will also cure a few other problems but will wipe out all current settings. Make sure you don't disconnect your phone from your sync connection with your computer durning the process... Good luck.. L J
Posted on May 27, 2009
I was also getting the same problem and now I found one solution. Just remove the battery from your phone for at least 15-30 minutes and then insert the battery again and switch on your mobile. I hope it will also work for you. Good Luck!!
Posted on Feb 11, 2009
T- Mobile WIng Screen Frozen
you probly got a bad digitizer (touch screen) so it does not know you are touching the screen it will stay there for ever untill problem with touch screen is solved
Mar 11, 2009 | T-Mobile Wing™ Smartphone
I have a tmobile wing the phone works fine but the touch screen does not work. i got the phone from someone and when i switch the sim cards it went to the screen that says to taap it to align the screen..i...
All you have to do is tap the screen with the stylus (slim pen that is position on the bottom right side of phone) where ever you see ( + ). Follow the plus sign ( + ) where ever it is on your screen. It should go in 5 different directions on the screen before it prompts you to the next screen. This process is mostly needed for hard reset (starting from original factory settings) or if you need to align the screen with the stylus.
Please make sure while performing the aligning task to tap the center of the (+) as possible. Not doing so may result in a poor functioning screen.
Mar 02, 2009 | T-Mobile Wing™ Smartphone
Locked internet on my tmobile wing
You need to have the network setting setup on the phone by your carrier. even though the phone is unlocked the current network setting are for t-mobile. if your not using t-mobile most of that stuff wont work.
Jan 03, 2009 | T-Mobile Wing™ Smartphone
My tmobile wing won't turn on
If you have an SD card in your phone take it out and try turning it on. You can take it out when you see it going back to the white t-mobile screen. Once the device is on and to the home screen you can insert the card again.
Oct 28, 2008 | T-Mobile Wing™ Smartphone
Tmobile wing screen searching for SD card
ok first you need microsoft sync on your pc second you need to download the wing update from t mobile it will walk you through the process the bars you are seeing means it is in flashing mode this software will fix the problem any questions e mail me at blok420@yahoo.com
Oct 05, 2008 | T-Mobile Wing™ Smartphone
Sidekick LX keeps shutting off and coming back on repeatedly
new beattery
or new phone.
batteries are cheap on ebay, , dont have a visa? just buy a ebay gift card from target..ect and then usee that too payy thee item off!
call tmobile 18777782106 dhats thee teechnical support line
Oct 01, 2008 | T-Mobile Sidekick
I have lost a button on my wing phone ( the button under the talk button)
I have had the same issue twice now, both times I was able to buy replacement buttons on e bay for about 10 dollars, however there is no instructions, and I think it was my fault it broke the second time because they are so delicate and difficult to replace without breaking a clip. However they are cheap and easy to find on e bay if you wanna chance the repair yourself!!
Mar 02, 2008 | T-Mobile Wing™ Smartphone
Cracked Tmobile Wing Screen
My Wing LCD has cracked twice. The problem is in the design, and T-Mobile will need to fess up.
Feb 07, 2008 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
408 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
