Question about Toys
Bottom propellers won't spin on my black spider xt
Had the exact same problem wire to gear was not welded properly reattach and done.
Posted on Dec 13, 2012
  • Clinton Mullis Dec 30, 2013
    take off nose cone check purple wire s atachednwith black yoll know what is wrong once yu see in there
    Problem Solver:
  • 7 Answers
You have to disassemble. but there are two motors. one for the top and one for the bottom. the gear probably slid down on the shaft. just pull the side off so you can see the gears and make sure they are lined up.
Posted on Jan 20, 2013
  • turab71
    turab71 Mar 17, 2013
    if they r not lined up?i m having the same problem :(
I bought three of these from CVS and all three had the same problem. The gear on the shaft for the lower rotor fell off the shaft. Unfortunately, I was unable to find them. I took the gear from one to fix another but I'm still down two toys. I'm going to try to get my money back.
Posted on Jan 11, 2015
Mine did the same thing, but mine was caused by one wire that broke off at the solder joint on the circuit board. The blue one in the attached photo is still connected to yellow adhesive of foam "bumper". It just happened for me, I will fix tomorrow. Bottom propellers won't spin on my black spider xt - bottom-propellers-spin-black-spider-xt-pskv230u5erjdk1mxnbyqgk0-1-1.jpg
Posted on Nov 27, 2014
I HAD THE PROBLEM THE TOP BLADE WAS NOT SPINNING AS THE BOTTOM BLADE DID. i TOOK THE SIDES OFF FOUND THE SMALL MOTOR GEAR HAD COME LOOSE FROM MOTOR SHAFT TOOK DROP OF SUPER GLUE ON SHAFT PUT GEAR IN PLACE FIXED PROBLEM.
Posted on Nov 17, 2013
  • 23 Answers
SOURCE: my helicopter wont fly
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Posted on Apr 04, 2010
bayyagg
  • 1672 Answers
SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Posted on Aug 09, 2011
  • 30 Answers
SOURCE: Where can I get copy of instructons - Air SBEGO Mini IR Helicoper
have you made sure that the helicopter is charged completely?
if so when you try to take off if it spins to the left then hit the r trim on the remote and if it spins to the right then hit the l trim on the controller.
honestly all the instructions do is tell you how to put batteries in the controller.
Posted on Dec 30, 2008
Don3542
SOURCE: My helicopter won't take off,
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Posted on Jul 11, 2011
  • 3 Answers
SOURCE: I cHarged the helicopter and
try to play around with the trimmer.. i had the same problem but then guessed it was the trimmer and iwas right!
Posted on Dec 25, 2010
Hey I recently bough a Propel RC Sky Force helicopter from a near buy store for a great price. However with that great price tag I figured something might be wrong, and something is my helicopter keeps...
take it to a different large chain store like the W world... and exchange it for a different one. Of course the store has to sell it there before you can exchange it. worst comes to worst, I always have good luck calling the company and complaining. I have gotten free vouchers for new items that way.
Jun 15, 2013 | Toys
Where can i get a copy of instructions for black spider xt indoor helicopter
You have to remove the cover on the bottom of the remote controller and take out the cord. Then take the cord and plug the end into the helicopter right above the on/off switch.
Dec 28, 2012 | Sky Toys
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
I cHarged the helicopter and can get the directional Propeller to spin but cAnnot get the main throttle proPellers to spin. Help
Dec 25, 2010 | JCPenney Gyropter RC Helicopter
Heli will not climb above ground effect, battery tests ok, axles in balance no vibration, just will not climb
I also have this kind of problem with my apache. The upper propeller must spin faster thatn the lower propeller if not the heli would just spin on its tail although maximum power is achieved. The solution is to check the connection of the gears and the axle of the upper propeller which is located at the bottom of the helicopter. remove first the battery pack to see clearly the connection. try to turn the upper propeller a few turns and see if the axle, gear and the metal connector is sliding. A fixed my heli buy putting a permanent glue on the axle, connector to the gear and whalla. it does not slide. Most problems of this model is the gear of the upper propeller, often times loosened specially during crushes. This will a lot help you as your heli would have power on the upper propeller for lift off. Happy flying.
Gerry1abe.
Mar 07, 2010 | Apache Colco Ah 64 Longbow R/C Helicopter
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Toys Logo
4,457 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
