Toshiba 20wl56b freeview. Setup - Televison & Video
No sound on my tv
Look in the setup screen and see if you are sending the sound to the correct place.
Aug 04, 2014 | Toshiba 40BV702B 40 inch full hd lcd tv...
Apart from the on-off button none of the panel or remote controls are working on my Toshiba 20wl56b t.v
I think problem is from the control board. The board works with the TV buttons and that's where the remote sensor is. If the board is defective or dead, the buttons won't work and the remote won't work as well.
I hope the above is clear.
Good luck.
Jan 05, 2012 | Toshiba 37WLC48 LCD Television
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
Cant get freeview
go to menu put it on dtv scan channels/if not its aerial
Apr 18, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have a Toshiba 20WL56B TV and I am trying to find out if it will be ready for digital tv when it switches next year or do I require a top box. Please help.
Your Toshiba has a digital tuner installed. You should not need a set top box. You are good to go.
I hope this helps.
Aug 24, 2009 | Insignia Televison & Video
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
