Fault code 37
How to fix fault code 37
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.I need to know the brand and model number of your machine.Looking forward to your reply.
Posted on Nov 30, 2012
  • Kuytim Alikay
    Kuytim Alikay Nov 30, 2012
    Fisher & Paykel. IW812
3 Suggested Answers
  • 4 Answers
SOURCE: top loading intuitive washer says fault code 37
This machine calls this error number for most faults.
So first let us know what stage it stops at.
The most common fault is blockage in the pump.
Remove the power plug, disconnect the 2 water hoses and tilt the machine onto its front.
It is simple to remove and replace. Disconnect the 2 sockets from the pump The pump is held in position by a latch on the left hand side. Depress the latch and twist the pump anti clockwise. Clean out , add a smear of vaseline to the rubber ring.
Reassemble in reverse
Posted on Mar 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: A message comes up that
F27 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. This is verbatim from the tech sheet. You will need to check to following:
1. First, UNPLUG the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, proceed to step 2.
2. Check the drain hose and make sure it is not plugged or kinked.
3. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
4. Check/Clean Drain Pump Filter of foreign objects.
5. Check for Drain Pump Failure.
6. Check the Inlet Valve for proper shut off
7. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pulling a vacuum on it with a shop vac. You may have an obstruction in the drain line or drain pump. It is also a good idea to check the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub and runs to the inlet side of the drain pump. This area can get clogged with small articles of clothing.
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the rear of the washer with all the wiring running to it). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the clear tubing (air hose) is still attached. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. This may generate an F27 error.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. Look for obstructions in the clean-out trap and impeller area of the pump.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off. You need to ask yourself if you find standing water in the tub when not in use.
5. The "Sud" error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent, HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause an over suds condition.
NOTE: Knowingly or unknowingly using the improper detergent on these model washers MAY void your manufacturer's warranty. Read all instructions and documentation that comes with the appliance, thoroughly.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a component failure (more commonly, the CCU or pressure switch)
Posted on Sep 15, 2010
Fault code 37
If you wish to get some details about washing machine service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 27, 2016 | Fisher Washing Machines
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer IWL12 fault code 37
Pump Ohms to low will smell like burning enamal
The pump will need replacing,
Apr 06, 2013 | Fisher and Paykel Washing Machines
Fault code 37 Yamaha V-Star 1300
Hi, Kenneth for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ERROR code 37
Yamaha Fault Codes
http://vstar1300.pbworks.com/w/file/fetch/94628933/1300VStarServiceManual.pdf
OEM parts for Yamaha
Yamaha 2007 XVS1300AW Owner Manual
Jun 15, 2012 | 2009 Yamaha V Star 1300
Iw712 fisher and paykel washer has fault code 37 what does that mean
37 is drain error..There could be electronic reasons, but the most common problem is that there is a clogged pump or something is jammed in the pump impeller... Empty the machine of water and lean back against the wall so you can get access to pump, which is clipped to the bottom of the drum..Try turning the fan and see if the pump is blocked'/jammed.....Disconnect the wires and rotate the pump motor anticlockwise...It will be prevented from turning by a small plastic latch. Unlatch and remove pump motor...Remove any detritus and refit pump motor....If the motor resistance is less than 33 ohms (230volt) or 7ohms (110volt)..the pump motor itself might be the cause of the fault code, and should be replaced......This is a very simple job for a tech...Good luck....Nomess
May 21, 2010 | Washing Machines
Top loading intuitive washer says fault code 37
Mar 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fault code 37
fault code 37. washing machine will not empty bowl.
Feb 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fault Code 37 Intuitive Washer -
you have a clogged diverter valve, its blue and looks like a Y, it will need to be replaced, if you want call 1-888-936-7872 they can order the part and walk you thru replacing it
Jul 04, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fault code 37
I would check the wiring near the starter for any problem, is it tight, not corroded and so on, if no issue is found there then the starter and or solenoid should be replaced, I almost always do both except were the starter solenoid is remote from the starter location like on fords, then test the remote solenoid 1st.
Aug 04, 2008 | 1996 Jeep Grand Cherokee
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
