Question about JVC KD-S890 CD Player
The faceplate display on my JVC stereo has a lot of dust inside it. Can I disassemble the faceplate and clean the inside? Everything works great, it is just more of an irritant!!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Yes, you can take the faceplate apart and use air pressure or a photo lens brush to remove the dust. You probably won't get all of it off as the dust is attracted to that area due to the static build up. You can try using an antistatic spray on the lens to try to dampen down the issue longer.
Posted on Nov 30, 2012
3 Suggested Answers
Duncan
  • 218 Answers
SOURCE: Lighting problem JVC KD-LH2000
If your unit is a "flip face" design then I would suspect that the flat ribbon cable that goes between the flip face and the main board has lost at least one of the leads and that the cable needs to be replaced. Try Partstore.com for a replacement. Good luck.
Posted on Jan 21, 2007
  • 10 Answers
SOURCE: My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
Posted on Aug 02, 2011
Hello, I have an odd problem with my Pioneer DEH-P9800BT Screen
Clean all contacts chemically and check all wiring for good, tight connections.
Aug 25, 2017 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Cant reset car stereo
my name is larry i have a 1999 gmcyucon and it stuck in 4 hi,
Feb 19, 2014 | Cars & Trucks
Why would a jvc radio keep saying miswiring?
I had the same problem , you have to reset the stereo , what you have to do is take your faceplate off , there is a little hole that says reset press it with a little pin for about 10 seconds and then put it back it should work now... let me know if works
Mar 22, 2012 | JVC Car Audio & Video
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVS UX S59, every time original disc inserted readsawhile and comes up saying no disc. please help, also adio not working. Everything was working fine, stereo has not been moved or dropped. Thanks Andy
the main problem with this is the laser .
the category 1 lasers are very sensitive .
the solution is to make sure your cd's are clean , not scratched and the final thing to do is clean the lenses of your JVC S59 make sure to keep this unit in a dust free enviroment .
Sep 26, 2009 | JVC UX-S57 CD Shelf System
I have a kenwood kdc-419 car stereo
Use a pencil eraser and try to clean the contacts on the back of the faceplate, if that fails it may have a cold solder joint on the inside of the face plate. May need replacement.
Jun 01, 2009 | Kenwood KDC-419 CD Player
I cant get the jvc radio to turn on time will display when pushed and it will take cd's and eject them
What model have you got/
It's 2 Possibilities of faults.
Either a diode leading to the faceplate connector has gone open circuit (common in JVC)
Your ignition supply is down (or the voltage regulator is not outputting the correct voltage to turn on)
I'm very sure it is the diode problem. I used to work for a national car stereo repair company, so if you need any help give me a call.
FixMyConsole
Mar 09, 2009 | JVC AM FM CD DET FACE CAR STEREO
Display is out
is it detachable face?? do you detach it a lot? it could be the connection between the faceplate and the stereo. gently push against the faceplate and see if it flashes back on?? BE GENTLE!!! maybe a slight wiggle while you push. if it flashes on at all you should try to have it serviced or replace it altogether. Good luck.
Jan 03, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Jan 21, 2007 | JVC KD-LH2000 CD Player
JVC KD-S890 CD Player Logo
80 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
