Question about Dewalt 18 Volt Compact Drill Kit
The drill bit came out of my xrp 12v dewalt drill. How do I get it back in? Is it locked?
  • David Ford
    David Ford May 11, 2010
    Can you be more specific, the drill bit came out or did something happen to the chuck itself, possibly the retaining screw? Let me know
  • 187 Answers
I hope I am understanding your question properly, if not, leave a comment. This drill *** a "keyless" chuck. If you look down into where the drill bit goes, there are metal pieces inside the black nose of the tool. Those metal parts are what holds the bit into place. The drill bit slides into the hole at the front of the drill (where it fell out from), Put the drill bit back in and then grasp the black tip (right below where you put the drill bit in). Directly underneath where you put your first hand, hold onto the piece directly below the upper part. Turn the top piece right and left and it tightens or loosens the mechanism that holds the bit in place. Give it a firm turn to make sure it is tight.
Posted on Nov 17, 2009
A dewalt dcd970 18v xrp and when i try to unscrew anything the bit comes loose. Can't figure out why?
check the inside of the chuck at the bottom(open the chuck to max). There should be small screw there with either a hex or a Phillips head. It is a left hand screw that locks the chuck in place and will not let it unscrew when you are removing parts.. If it is not there then you will have to get one from an old drill that is junk unless you can get one from an electrical appliance shop the repairs drills.
Oct 24, 2011 | Dewalt Air Tools & Compressors
Will a dewalt 12v xrp battery fit and run a 12v firestorm black & decker drill?
Don't know for sure but most batterys are made for each kind of drill.
Jan 19, 2011 | Black & Decker 12V Xrp Drill/Driver
I cannot get the drill bit out.
Needed -2 pair of adjustable pliers.
Hold the chuck with one pair, hold the hand chuck with the other pair turn in opposite directions to loosen bit.
Take care not to mar the plastic on the chuck.
Dec 24, 2010 | Dewalt 12V XRP Battery Pack
Drill chuck stok in the thigt possition cant get the bit out ; cant make de chuck to open or close
Sometimes this happens when you have a drill bit that slip. Take a pair of channel lock pliers, and try and turn the chuck counter clockwise. Do it sharply so the drill doesn't turn. IF that still doesn't work put the drill in reverse and try the channel locks again
Jul 05, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt XRP chuck is locked tight on a 1/8'' bit. Can't loosen chuck.
take 2 pr of large channel locks and grab both sections of the chuck, on section in each channel lock, and use this to break it loose
Dec 05, 2009 | Dewalt 18 Volt Compact Drill Kit
Having trouble changing dewalt 14.4 v xrp cordless drill bit
hold black chuck and put in reverse if dont work spay wd 40 in and around where drill bit goes and let sit a few hours
Sep 12, 2009 | Dewalt Heavy Duty XRP 1/2" 14.4v cordless...
Drill bit came out, won't go back in. Dewalt 12v XRP
grasp the chuck and put drill in reverse position and pull trigger gently this will open chuck and re-insert bit do same in forward to tighten bit into chuck
Jan 10, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
202 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
