Question about Hardware & Accessories
My Jasco time has a red , black, white and green wire while my outlet has only a black, white and green wire. Should I attached the red & block from the timer together? Thanks, John
  • 5,245 Answers
Copy following link for replacing single-pole switch with single pole 15086 / 15071 GE timers.
http://waterheatertimer.org/How-to-wire-timers.html
Copy following link to identify GE timer:
http://waterheatertimer.org/GE-timers-and-manuals.html
Copy following link for GE 15312 single-pole and 3-way timer
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
Posted on Nov 30, 2012
  • 351 Answers
SOURCE: Trying to replace Intermatic with Utilitech inwall
The wires on your new switch are intended for black = power .. white = neutral . and red = lights .. with two black wires on the old switch I am assuming that there is a bundle of white wires in that wall box, the white timer needs to join that bundle ... then you need to determine which black wire is the power from the electrical panel ( voltage tester) and connect to the black timer wire .. the red timer wire connects to the other black wire in the wall..
Please Vote !!
Posted on May 13, 2010
SOURCE: I bought Utilitech #0141224 7
Hello, I bought an in door smart digital timer (G.E.) or Jasco product for my front porch light. I hooked all the wires as instructed and programmed according to instructions. I have a two wire system, so i left the green wire unattached. The light comes on but flashes very fast. What's up with that? This is the second one i've replaced, the first one did the same thing!. Whats wrong?
Thanks,...
M Jones
Sacramento, CA.
Posted on Sep 13, 2010
SOURCE: GE digital timer. Instructions say to: 1)
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Posted on Sep 26, 2010
SOURCE: installing a GE digital wall
Review:
Black goes to Hot wire from breaker box
Red wire goes to Load (light, fan, motor)
White wire goes to Neutral
Green to bare copper ground wire
Orientation:
Your original switch had 2 wires plus bare ground.
One of these wires is Hot, the other goes to Load.
You said original wires are Red and Black
How do you find Hot wire?
-Your original switch had 2 wires.
-Remove timer from box.
-Pull original 2 wires out where you can test them
-Turn on power
-Use regular tester
-Tape tester leads to wood sticks so your hands stay away from voltage
-Power is on
-Test each original wire to bare ground wire
-When tester lights up, that is Hot wire ... this wire connects to Black wire on timer
- The other wire goes to Load so it connects to Red wire on timer
How to test for Neutral wire
Test Hot wire to your white wires - No need to untwist them.
When tester lights up, that is Neutral
White wire from timer connects to Neutral.
Green goes to ground wire.
How to reset timer
I'm not sure which timer you have. Probably GE 15086. Reset is small round button below HOUR button. Use paper clip and push-in reset until timer flashes 12 o'clock.
Posted on Sep 30, 2010
If your box contains 2 and only 2 wires, then the Utilitec timer will not work.
You need the Intermatic ST01C or EJ500 timers that operate with a battery.
I have tested the Intermatic and Utilitec timers:
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
http://waterheatertimer.org/ST01C-program.html#wire
Do not connect white and red wires together on any timer, but thank you for solving the problem why lights blink when connecting timers.
Now lets look at your wires.
Scrape paint off the wires so you can identify white and black.
According to your information, the black wire inside box will connect to timer-black wire.
The red wire always goes to Load (your light, fan, motor)
The white wire is necessary to complete a circuit so the clock inside timer will operate.
The timer has a clock just like your alarm clock, and it needs to connect back to neutral busbar in breaker box.
This is why the battery-operated timers will work with two wires, the clock runs on battery.
The Utilitec timer-white wire is the wire that goes to Neutral
The timer-white wire is supposed to connect to the other white wires that are twisted together and covered with a wire nut ... but some boxes do not have this neutral wire
To work-around, the timer-white wire can also connect to a bare ground wire.
The bare ground wire also connects to Neutral busbar in breaker box
If you do not have a neutral or ground wire as described above, then you need the battery-powered ST01C or EJ500 Intermatic timers.
See if you can pull some more of the wire into your box ... there might be a ground wire that was cut off and pulling more wire might reveal a ground wire. This will salvage the project.
Aplus is one of many places that sell the Intermatic timer
http://www.aplussupply.com/intermatic/timer.htm
For more about electric wiring:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
Posted on Oct 24, 2010
How do I install the 4 prong electrical cable to the dryer?
I would attach the black wire to the black & yellow, white to white, red to blue & brown. The green wire is your ground wire and needs to be attached to the cabinet. On the connection where your white wire is located see if there is a copper strap that goes from the terminal block to the cabinet. If there is, you will need to remove that strap and attach the green wire to where the strap was attached to the cabinet. Hope this helps!
Sep 16, 2014 | Dryers
I am installing a 30 amp cord on my Whirlpool dryer. The model number is WED5100VQ. I am having a problem finding the ground wire in which to ground the dryer because it only has a white wire coming from...
On whirlpool (all manufacture) dryers the ground wire is linked to the center terminal with the white wire and attaches to the cabinet grounding all metal on dryer since on panel attaches to the next making the entire cabinet have continuty through the neutral/ground wire.
When connecting 3 wire cord connect the two outside wires to red/black on cord block and center wire to white/center terminal connection on block.
For a 4 wire cord red to red black to black white to white and the green to rear of cabinet/any panel near block
(same question listed 2 times gets same answer 2 times)
Aug 13, 2011 | Whirlpool Dryers
4 prone receptical in house,4 prone wire,3wire machine how do i connect
As for the red and black of new cord connect on red and black on terminal block on back of dryer for the white it will have a brass link that connects from the white terminal on block to the dryer cabinet.remove that brass link attach the green wire to where the brass link attached to the cabinet and the white onto the terminal block
Jul 28, 2011 | Maytag MDE9700AYM Electric Dryer
I have a marathon 3hp motor wired for 220 on a campbell hausfield air compressor. It has a white, black, and green wire coming out of the motor. I am using a no. 12 wire with ground. how do i wire it up to...
Hi! sims146
The Green wire from the electric motor is ground. Check the compressor motor, make sure it is wired for 220-230 Volts. If it has a white wire it could be wired 120 Volts. There should be voltage and current ratings on the motor plate. I always double check these connections. At 230 Volts this motor should be 17 Amps full Load. A 25-30 amp fuses are required to protect this motor circuit. Otherwise up to a 42.5 Amp Inverse Time Delay Breaker could be used.
The welder circuit should have 230 Volts between the Red and Black wires. The white wire is Nutral / Ground. Hopefully this is a 30 to 40 Amp circuit. The Four prong air compressor outlet, White is Neutral, Black and Red 230 Volts, Gray should be ground. Please check with Voltmeter, as some times people swap colors.
InMrFixIt
Jun 25, 2011 | Garden
I have connected the Black wire to the outlet black wire and the red wire to the outlet white wire. The timer has a white wire, is this suppose to connect to the outlet ground wire? The timer turns...
I have extensive files on timers and don't recognize that GE number.
Possibly you have GE 15071 or 70 or similar timer.
Open following link to identify timer, and read step-by-step wiring.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 08, 2011 | Jasco GE 06685 24Hour Mechanical Timer...
On the top of the dryer there is block where the power cord attaches and there are 6 spaded treminals wit the following wires attached from left to right they are black wire, 2 blank, whiye double wire,...
the green wire is the ground wire,there should be a screw or connector for it near the block,it just connects to the frame so the unit is grounded,you should see on the cord a white,black,red and a green ground wire,on the block you should see the white wire connected,the black on another screw and the last one is for the red,if the white is in the middle the black should be on one side and the red on the other,they are color soated,if you say there are red small wires the large red should connect with them just like the black does,as long as you keep the white wires together,the black wires together and the red wires together you'll be fine and ground the green wire to the frame
Feb 22, 2011 | Dryers
Kenmore model 110 ele dryer has 3 wires giong into outlet but outlet is going to be connected to a 4 wire supply. red black white green which color is hot what color is ground how do i connect the...
This sounds like you should call an electrician, or someone that knows wiring. Red and Black are both hot, White is neutral, and Green is ground. Remove the ground strap from the center of the terminal block to the case. Put green wire to the case, white in the middle, and red or black to either side. Your last question I do not understand. But it sounds like you need an electrician to connect a 4 prong receptacle, with the proper 4 conductor wire to your breaker box.
Jan 01, 2010 | Kenmore Dryers
Changing electrical Cord from a 3 prong to a 4 prong. I need a wiring diagram
black to black lug white to white lug red to red lug green to ground(any bolt that is attached to body of dryer)
Dec 20, 2009 | Whirlpool Dryers
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Feb 14, 2008 | Dryers
Hardware & Accessories Logo
208 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
