Question about RCA D52W19 52" Rear Projection Television
RCA D52W19B light on power switch blinks 3 times no power on. May be capacitors on power supply/deflection board. Where is board located when looking at back of tv and a description would help?
  • 1 more comment
  • shmeg2332 Jan 16, 2009
    We just got ours looked at...same problem..guy said the power supply needs to be replaced for $270...is that a good price?
  • neffje Jan 26, 2009
    we try to turn tv on and get the flashing green light. We were able to get TV on and as long as we didn't turn the TV off we were fine. Well, it got turned off accidently and now will not turn back on. We were quoted $225 to fix it.
  • tvsdntn Feb 01, 2009
    I had the same problem--the green light flashing 3 times. From this website, they said it was mostly likely the flyback 259296. I changed that and it did not work. I noticed the cp150 was bulging out on top--changed that and it works like new. A $2 part fixed my tv. Look in the back and inspect, yours could be the same.
Where do ypu get the cp150 at thanks
Posted on May 16, 2009
    Problem Solver:
  • 5 Answers
I had the same problem with the power switch blinking 3 times. From this website it sounded like it was the flyback 259296. It wasn't. I noticed the cp150 was bulging out on the top. Changed that and it now works. CP150 was only $2 and the flyback was $60. Bought the flyback for nothing
Posted on Feb 01, 2009
I have a rca 61" rear projection r61wh76. when i
That is normally caused by failed capacitors on the deflection board or also the flyback could be bad also located on the deflection board. Your board is the PSB260 deflection which is available from www.tvrepairworld.com
Jul 18, 2011 | RCA Televison & Video
My RCA D52W14 wont turn on it makes a weird noise and the power light blinks as it's making the noise three times than the blink stops and noise too
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 12, 2010 | RCA D52W19 52" Rear Projection Television
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Bad capacitors? ladywinn
If you take the back off the deflection board is the one on the left. You must remove the board and near the front you will see a capacitor with a puffy top. Replace this one and the three closest capacitors around it. Not easily done unless you have some experience.
Apr 09, 2009 | RCA R52WH73 Projection Television
RCA 52 in tv
ON Deflection board there is 3 capacitors that most of the time will cause set not to startup cp150-cp114-cp120. values 2200uf 16v, two 220uf 35v, you buy caps at Radio Shack.
Dec 28, 2008 | RCA D52W19 52" Rear Projection Television
Come on and goes off
3 bad capacitors located in front of deflection board cp150 cp111 cp114 they are green with gold writing on them if cp150 is bubbled up on top it is bad. 2200uf 16v. so replace all 3 capacitors.
Nov 22, 2008 | RCA HD52W59 HDTV Projection Television
3 green blinks
Look on Deflection board cp 150 2200uf 16v capacitor and there is 2 more capacitors 220uf 35v replace both of them. Green and Gold writing on caps.
Sep 09, 2008 | RCA D52W19 52" Rear Projection Television
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
631 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
