Question about Konica Minolta magicolor 2430 DL Laser Printer
1 inch top margin - Konica Minolta magicolor 2430 DL Laser Printer
  • 2 more comments
  • leisj
    leisj Nov 30, 2012
    I'm getting a 1 - 1.5 inch margin at the top of every page, this includes test pages.
  • Brad Brown Nov 30, 2012
    See page 32 http://www.inkcloners.com/Service-Manual...
  • leisj
    leisj Dec 07, 2012
    I checked Page 32 which talks about the Direct Print configuration. I have also loaded the printer defaults
  • leisj
    leisj Dec 07, 2012
    The extra margin is exactly 1 inch.
  • Konica Minolta Master
  • 17,115 Answers
What about it?
Posted on Nov 29, 2012
  • leisj
    leisj Nov 30, 2012
Adjust top margin of doc?
Look in the preferences of your printer.
Terry
Oct 10, 2014 | Dell 1100 Laser Printer
MG6120 printer starts printing 2 inches from top of page
I want to say it stems from whatever program you are using the print. My guess would be your margins are set two inches from the top. If that's what it is it is easily correctable. You just have to check your margins and access the number back to one you want to use. Otherwise it could be your nozzle alignment which you may want to run some maintenance and try to fix the nozzle alignment.
Aug 27, 2014 | Canon Pixma MG6120 InkJet Printer
Why doesn't it print on LABELS at the top of the page?
I share a link please visit and follow step by step instruction.
I hope solved your issues.
http://ulearnoffice.com/word/printing.htm
Thanks,
HP Printer Support
May 30, 2014 | HP LaserJet 1020 Printer
Pt 65 margins
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 20, 2014 | Brother PT-1000 Thermal Label Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Check Your Margins
Select New Margins
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
Printer not printing margins correctly
Set the margin unit of measurement to whatever you find most useful: inches, centimeters, millimeters, points, or picas.
  1. Choose File > Options > Advanced.
  2. Under Display, in the Show measurements in units of box, select the unit you want.
Mar 24, 2017 | HP Office Equipment & Supplies
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
How to set page margins in inches during page setup
Go to the print preview option and double click on the scale at the top. It would allow you to set the margin in inches.
Jan 27, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
I need to know if there is a way to change the top margin (first print line) on a Lexmark 250DN printer. The first print line is about 1/2 inch from the top. I need to start printing 1/4 inch from the...
You change the margins in the word processor application, not the printer. You did not list what application you are using.
In microsoft word, you click on "file", then click "page setup". This will give you the correct dialog to change your margins. Really simple and easy.
For futher questions like these, use google search.
here is one i found using google:
http://office.microsoft.com/en-us/word/HP052292751033.aspx
All I did was type "how do i change the margins in microsoft word" into google. It will be a lot faster searching on google than waiting for a fixya reply.
Feb 08, 2008 | Computers & Internet
Konica Minolta magicolor 2430 DL Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
