Question about Jenn-Air JDB6510 Built-in Dishwasher
Won'Run Wash Cycle
Unit has power, door latch switches tests good and output 120v. Does not start water pump or motor. Found and replaced timer assembly. noticed burnt connectors, so that was definitly bad. still have same problem. Unit has power but nothing happens when i set it to run. Any suggestions?
  • 5 more comments
  • John breen Jun 06, 2007
    by thermal cutout do you mean the thermistor limit switch?
  • John breen Jun 07, 2007
    yes i checked it... its closed as it should be i believe. I did notice a dried oil maple syrup coloered pool on the floor underneath the motor. Any ideas?
    Catriver,
    I will check that 2 nite, i do have the electrical schematicfor this. I noticed in the motor section there is a "Overload protecter" it has a fuse like symbo that looks like a sine wave what is it? is it accesible?
    Thanks
    jb23
  • John breen Jun 09, 2007
    No voltage to the motor wires
    disregard the last comment, thereis 120 volts down belwo, I did measure this 2 pronged device that is mounted in the motor on the bottom, there is no continuity,it called a overload protector is parralle with the motor windings according to the schematic.
  • John breen Jun 12, 2007
    shorted internal overload wires and it works that part is on order
  • Anonymous Mar 23, 2014
    Have power to unit have Power when door is latched but nothing will come on
    Sergeant:
  • 279 Answers
Did the part come in for this, and is it working now?
Posted on Aug 31, 2007
    President:
  • 878 Answers
JB, make sure the float assy. is not stuck inside the tub. On the motor harness, you have yellow-main, red-drain grey-wash and blue is the common. Check for power to the motor during the wash cycle. On this model I believe they installed a thermal cut out after series 11. I'll keep an eye peeled for any replies..Catriver.
Posted on Jun 06, 2007
  • 1 more comment
  • Ron Marek
    Ron Marek Jun 07, 2007
    jb, it's a limiting thermostat, sits on the bottom of the tub, undernieth, inline with the heaters. Check to see if it's open, Did you have power to the motor during the wash cycle? Catriver
  • Ron Marek
    jb, did you do the voltage checks at the motor? The dried oil, syrup looking stuff could be coming from the start capacitor for the wash motor. If that's bad, motor won't start. Catriver.
  • Ron Marek
    Ron Marek Jun 09, 2007
    Jb, I think you found your problem, power to the motor and motor isn't running. During the wash cycle, Grey to blue should be reading 120V. The motor does have a internal overload. Catriver.
Have to slam dishwasher door to make it go electrolux 4000
Hello David Horn - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 18, 2012 | Electrolux Dishwashers
My frigidaire professional series dishwasher has no power
Hello qmainous - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 16, 2012 | Frigidaire Dishwashers
Dishwasher not starting
Hi Mike Heneghan - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 11, 2012 | Frigidaire FPHD2481KF Builtin Dishwasher
Frigidaire dishwasher model #FDBB945DCO will not work power is on but control panel is dead
Hi Janis Angileri - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 30, 2012 | Refrigerators
Door latch not working on Frigidaire 18 in.
Hi -
Oct 21, 2012 | Frigidaire 18 in. FDR252RB Built-in...
Frigidaire dishwasher has no power and won't start
Hi - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 17, 2012 | Electrolux Fridigaire Lp Conversion Kit...
Model #EDW5500DSS1
Oct 16, 2012 | Electrolux Frigidaire Professional Series...
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    Dishwasher will not start
  • Door latch.
    Make sure door is closed and properly latched.
  • Delay start option.
    If delay start option is available, has it been set and is unit still in time delay before starting.
  • Cycle setting.
    Check to see if cycle is set correctly (refer to Operating Instructions in the "Use & Care Manual").
  • Jul 25, 2008 | Whirlpool 24 in. GU2548XTP Built-in...
    Bosch shu8806
    the pump may be clogged, or the motor start capacitor may be bad or some units have a fill switch wired inline with the motor so it won't start unless the unit is full
    Nov 20, 2007 | Bosch 23 in. SHU 8805 Built-in Dishwasher
    Jenn-Air JDB6510 Built-in Dishwasher Logo
    129 people viewed this question
    Top Jenn-Air Dishwashers Experts
    Marvin
    Marvin
    John Tripp
    John Tripp
    Mike
    Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
