Question about Sunbeam 275 Watts 2369 MixMaster Series Hand/Stand Mixer
How do you use the bread dough beaters?
I don't have a manual. I would like to try to make bread using my mixer
  • Sunbeam Master
  • 5,102 Answers
Retrevo has link to the Instruction manual for the MixMaster 2369 here: http://www.retrevo.com/support/Sunbeam-2369-manual/id/952ci068/t/2/ . You will need to enter a code to download the file. You will also need Adobe Reader or a similar program to read the file.
I hope this helps.
Posted on Nov 30, 2012
3 Suggested Answers
Loringh
  • 185 Answers
SOURCE: Mixer beaters clanging together
The beaters might be fixable/replaceable but the bowl not spinning anymore is the more serious of the 2 problems. If this is several years old iit probably is more cost efective/simpler to replace the whole unit.
Good luck Loringh
Posted on Nov 09, 2008
whlyon42373
  • 71 Answers
SOURCE: Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Posted on Dec 15, 2009
Testimonial: "I will try the rubber bands the next time I use the mixer - Thank you"
Beaters are hitting each other and jamming up
One of the beaters had jumped a gear. I understand they are nylon gears. My wife's had the same trouble. I unplugged the mixer, removed the bowl and install the beaters if you can to see where they are touching. They were two cogs off. I grapped the left (red) beater firmly and twisted it to the left. It took a couple tries and turning on the motor (with out beaters) to find the spot where they had skipped. In the end the left beater jumped back one then two teeth and now the beaters aline properly.
This will happen again with heavy dough, etc. now that the teeth are worn in that spot. Use a bread machine for the heaver dough. IMHO
Dec 12, 2012 | Sunbeam 2346 Heritage MixMaster Series...
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
My mixer just started smoking while i was mix some
Your mixer may still be good, let it cool down and then check it out, If it runs OK then there is no problem. The motor in your mixer probably over heated from trying to mix bread dough which will make any mixer work hard. These mixers will get warm when over worked but unless heavy smoke was coming out and you were getting a burning enamel smell it is probably OK. Let it cool and try it but I suggest you not use it for bread any more.
Oct 08, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Professional 600 - makes loud noise when mixing,often stops as it blends 8 cups of bread flour and "needs a break", flat beater seems to get caught on bottom of bowl - this mixer is 1 yr. old!!
Several things:
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
Jun 24, 2009 | KitchenAid Food Mixers
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
LOOKING FOR RECIPE FOR MAKING BREAD DOUGH IN MY KITCHENAID KSM90 MIXER. I HAVE NEVER MADE BREAD IN MY MIXER, I DO NOT HAVE A MANUAL.
Hi Manfredi. Follow this link to download your mixer's manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Instructions%20and%20Recipes%20-%209704323.pdf
If this solution has assisted you, please rate it. Good luck, and don't overload the mixer when you're making bread dough. ricardok45
Mar 20, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Replacement Beaters for GE Hand Mixer
Hi, replacement beaters can be found at amazon, click here and take a look: Amazon com hand mixer beaters. Wish you best of luck.
Ned
Dec 02, 2008 | Black & Decker MX55 PowerPro Hand Mixer
Beater jams
You are going to DESTROY YOUR MIXER by kneading dough with the flat beater. Read the directions. They spell it out in big letters. Only use the dough hook for dough; only use speed 2.
If the mixer generated enough torque to knead dough with the flat beater (it doesn't), it would tear up and overwork the dough. As it is, you're lucky you didn't strip a gear.
Dec 23, 2007 | KitchenAid KP2671 Professional 6 Series...
Sunbeam 275 Watts 2369 MixMaster Series Hand/Stand Mixer Logo
120 people viewed this question
Top Sunbeam Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
