Question about Samsung DLP HL-P5663W 56" TV
WHY DOESSAMSUNG DLP BULB KEEPS BLOWING
HAVE PUT 2 NEW BULBS IN THE LAST 30 DAYS? NEVER HAVE HAD THE INTERMINTENT CUT OFF THAT I HAVE READ ABOUT.
    Top Expert:
  • Samsung Master
  • 74,377 Answers
When replacing the bulb, it is will be best to replace the ballast also. Make sure that the bulb is of original replacement part.
Posted on Nov 30, 2012
Hi, I have a Brother 1034d serger and it's practically new bought it in December last year and just started using it I made 8 skirts and the light bulb keeps blowing. I went to the store Lowe's and found a...
the main problem with blowing light bulbs on sewing machines is arcing caused by a loose ground that touches on the side of the bulb base as it screws in
disconnect the power from the wall sacket
use a suitable implement and bend that ground piece back towards the center of the holder so that you have a resistance when screwing in the new bulb
The arcing is in fact power fluctuations that have spikes or surges and bulbs do not take kindly to that sort of power problems
Only the bulbs from sewing machine spares shops should be used as general purpose household bulbs are not always successful because of the vibrations caused as the machine is sewing
Sep 07, 2017 | Brother Sewing Machines
Whirlpool gas oven light bulb lasted 5 years but now keeps burning out?
all appliance bulbs are not created equal it needs to be specifically an oven bulb to take the heat .
Feb 14, 2016 | Whirlpool Accubake 30" Self-cleaning...
The bulb keeps failing it has only been in 2 months
most underwater quartz light bulb rely on the ponds water level to cool the bulb housing , if your ponds water level is maybe not so consistant , look into buying those new L.E.D bulbs there more costly but last longer and don't have any cooling issues like quartz bulbs do
but caution if you rely on heat from bulbs to maintain a ice free pond then led is not the way to go as they don't put off much heat
Sep 13, 2015 | Garden
Blowing fuses to the tail lights and parking lights
You have an intermittent short circuit to ground somewhere. Start at the back of the car, and remove the tail light assemblies, with the bulbs disconnected. If you have an aftermarket towbar fitted, look for shorts on its wiring. Look for any squashed on burned wires. Put in a new fuse and add bulbs till the fuse blows to track which circuit has the problem.
Feb 11, 2014 | Subaru Impreza Cars & Trucks
My 6d maglite keeps blowing the bulb
6D Maglite? As in 6 D cell batteries?
1-1/2 Volts (Each battery), times 6 = 9 Volts.
Using the proper bulb?
The original is a Krypton bulb. (No, I didn't make the name up)
http://www.toolup.com/maglite_lmsa601_mag-num-star-6d-relacement-bulb.aspx
http://www.batteryjunction.com/maglite6c.html
Guess what happens if you put a 3 Volt bulb with 9 Volts?
Regards,
joecoolvette
Nov 27, 2012 | MagLite Mag-Lite& Flashlight
My tail light on my 2003 jeep liberty (left and center only) keeps blowing out I even replaced the entire light socket and it still does it. Is there a relay that I should check. If I replace the bulbs,...
The first thing is to make sure there is no water getting into the lens. there are alot of cheap bulbs out there that dont last long at all, you replaced the socket which is good try this , when you buy a bulb get it from the dealer they will sell you a better bulb it will be a long life type bulb and if theres still a prolem them you will need to have the wiring checked to make sure theres good connections . a bad power or ground wire will destroy the bulb cause a higher than normal amp draw and poping the bulb.
Sep 24, 2011 | 2005 Jeep Liberty
Periodically my 52HM95 would have some little electrical glitch where it would not come on when I turned the tv on. I would have to wait a little while before I tried again, or I could shut the power off...
I have a similar DLP TV. If you losing your new bulbs that quickly there is likely a problem with cooling. There is a fan that keeps bulb cool. Make sure the fan is working and there is nothing blocking the air passages. I have not had a problem with my fan but you should be able to find a replacement at Radio Shack or a computer/electronics store like MicroCenter. They come in standard sizes just make sure the voltage is correct typically 120 VAC or 12 VDC.
I have had the computer inside crash such that the sound would work, the bulb would come on, put no picture. Fixed by unplugging the TV for one minute then plug in and turn on.
The bulb repeatedly goes through its startup cycle but never comes on. It tries about ten times then stops. Fixed by removing the bulb housing and firmly tapping it on a counter top ten times. This was at Toshiba instructions over the phone and it actually worked.
Dec 31, 2010 | Toshiba 52HM95 52" HDTV Projection...
How long do bulbs generally last?
Generally, a DLP bulb lasts about 8,000 hours (if a TV is on 10 hours a day, every day, the bulb will last about two years). A bulb can last longer if it's used less frequently. Typically, a bulb in a DLP TV for household use should last at least three to four years before it starts to flicker and needs to be replaced.
Thanks!
Tim
Oct 02, 2010 | Samsung HL-67A510 67" DLP HDTV
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
Why does my fuse keep blowing for my tail lights in my 96 plymouth breeze ?Every time I put fuse in it cut the lights on the fuse blows?
The fuse keeps blowing out because there is a short circuit. Check the tailight sockets for corosion. Is there a tow package wiring installed?
Jul 26, 2009 | 1996 Plymouth Breeze
Samsung DLP HL-P5663W 56" TV Logo
106 people viewed this question
Henry  Thomas
Henry Thomas
