Question about Radio Communications
Motorola talkabout t5710s won't recieve
Two radios are configured exactly the same - channel, interference code, and qt off. A few days ago, the problem was I could send from A to B and it would work fine, but when the PTT on B was pressed it, no ack beep or voice came out of A. You could hear slight static on A while the PTT button on B was pressed, so it knows there is some kind of connection. Now today, both radios have the same behavior as the bad one before. I can PTT on either one, I hear a slight static on the other but no voice or the ack beep. The ack beep on the sending unit sounds normal. Also, in either case sending the alert tone doesn't work either. Batteries seem good, hold a charge and show full meter. Tried changing interference setting to different values.
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
The question I would ask is:
How close are the two radios to each other when you contact from one to the other?
A distance between the two radios of about 10-15ft, preferably more is desirable to achieve audible results, having the closer than 10ft, causes one to cancel the other out, so you either hear static, feedback or nothing.
Try 15ft of more distance between radios and see what happens.
Pls feel free to post the results here on the two way radio forum, as I'm interested to find out what happens.
Cheers, Peter@FixYa Team
Posted on Mar 19, 2013
SOURCE: Motorola Talkabout T5400
Hello, There is not compability issue, sounds like you have a mic problem because you hear the Roger Beep and that means that the transmition and Reception cicle is working if you could test an audio accesorie would be great. There is another possibility if one of the radios is out of frequency you could experiment the same symtoms.
Posted on Apr 16, 2007
driveallnigh
  • 89 Answers
SOURCE: We have 4 T8500 - only one can talk, the other 3 only recieve.
Can you tell if the radio is actually transmitting? Is there any sound on the transmitting radio or a light inditcating that it is indeed transmitting? If not maybe the PTT button is malfunctioning. Try to use a microphone plugged into the accessory jack and see if it works. Another option is if you have a radio scanner, search the frequency range while transmitting and see if you pick up that open carrier.
Posted on Feb 26, 2009
alexis_garci
  • 4 Answers
SOURCE: Motorola T8500 Communication Problem
Agree with eradiostore, check your batteries and battery contacts. Remenber to turn off the radios before charging.
Posted on Jun 12, 2009
  • 10 Answers
SOURCE: I have a pair of Motorola Talkabouts T5725 in
No if they power up the batteries should work are they both on the same PL code you have to set the channel and the code the same.
Posted on Nov 21, 2009
  • 33 Answers
SOURCE: Beep tone when I press the "mon" button, phone won't receive.
sounds like one has a low battery.
Posted on Mar 02, 2010
4 radio communication
Pls swotch off qt & keep the same channel also keep all privacy codes to 0 , try ur set it will get connected to rest 3 , do not forget to keep privacy code 0
Jun 05, 2013 | Motorola Talkabout T5500 (7 Channels)...
One of our two radios (Motorola T5720) recieves but when you go to talk to someone else they cant here you. I have made sure that we were on the same channel.
Check your Code (interference eliminator code) and your Qt filter (if any) to see if they match the other units.
Best regards.
Aug 29, 2011 | Motorola Talkabout T5720 (7 Channels)...
I cannot set QT filltering on..why?
Here are the instructions from the manual:
To transmit to a radio that has QT noise filtering turned on:
1. Select the same channel and Interference Eliminator Code as the other radio.
2. Press 'musical note' button to send a call tone. This allows your voice to pass through the QT
noise filter on the receiving radio.
3. Press the PTT and speak normally.
Note: If you skip step 2, the beginning of your message may not be heard on
For a 30-second period, starting after the last transmission, all transmissions
received on the selected channel and code will pass through the QT noise filter.
Also, your QT filtering will NOT work if you are in scan mode.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Aug 06, 2011 | Motorola Talkabout T5720 (7 Channels)...
We have two talkabout t5720, both set on same channel. One seems to send, while the other does not. we haven't used them before-is there a simple solution? Thanks
Yes. The solution should be simple. The radios are possibly not set to the same interference eliminator code and/or Qt filter setting. Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
You will find the programming instructions begin on page 21.
The frequency, code and Qt filter must be set identically on both radios. For simple basic operation set the code and Qt filter to zero (off).
Best regards.
Mar 14, 2011 | Motorola Talkabout T5720 (7 Channels)...
The radios are on the same exact channel but will not connect. One radio works fine, the other one will only receive. But if it is used with another motorola radio it works fine. The quiet filter is not on...
Recheck your Frequency, Interference Code Eliminator and the Qt Filter. If all 3 are set identical. If this doesn't clear up the issue. Next set your Qt Filters and your Code to zero (off). Lastly, on the radio which has problems transmitting, check your battery. A bad battery will cause intermittent transmit issues. Trade the battery with a known good battery and see if the problem clears up. Clean your battery contacts with a pencil eraser.
Nov 04, 2009 | Motorola Talkabout T5720 (7 Channels)...
One radio not recieving
You need to check your interference eliminator code. It sounds like they are not set to the same code. Also, if your radio has a Qt filter, set it to zero.
Here's a link to the manual http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Aug 11, 2009 | Motorola Talkabout T5400 (14 Channels)...
1 talkabout not working
Check the programming of the channel, interference eliminator and the Qt filter. These must match on both radios. Here is a link to the user manual to assist you: http://direct.motorola.com/ENS/T5920_T5950%20User%20Manual.pdf
Feb 17, 2009 | Motorola Talkabout T5950 (7 Channels)...
Motorola T6510 Talkabout powers up, but won't send or receive
On this model there is no shortcut to restore the factory defaults. However, if you walk through all the steps of the programming menu and make the radios identical, pay particular attention to the Qt filter. This is different than the interference code eliminator. Set your Qt filter to zero for the best results.
Here is a copy of the user manual: http://direct.motorola.com/ENS/T6500%20Series%20User%20Manual.pdf
Sep 21, 2008 | Motorola T6510 XLR Talkabout Two-Way...
Motorola Talkabout 2 way radio model T9500
You might check your Qt filter to see if it is turned off. You can find the instructions on page 2 of the user manual.
http://www.hitechwireless.com/pdf/T9500RManual.pdf
Sep 08, 2008 | Motorola Talkabout 25-Mile, 22-Channel...
Pair of radios won't talk to each other
Have you checked the QT filter? The T5950 have an addtional interference filter called the QT filter. It filters out other radios and allows Motorola radios to speak only to other Motorola radios with the filter. Check the QT setting on both radios by pushing the menu button 6 times, the QT setting will show. If it shows a straight line on the display the filter is not on. Now push the + button (beside the menu button), to turn the QT filter on (a Y will show on the screen when on) or the - button to turn it off (the line will show when filter is off). The radios have to match all channels and all filters to talk to each other.
Dec 09, 2007 | Motorola Talkabout T5950 (7 Channels)...
Radio Communications Logo
271 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
