Question about GE Refrigerators
GSH22JFXBB Fan is running in the freezer, but the compressor is not turning on. I flushed the hose, but that did not work. What else can I do?
  • 236 Answers
SOURCE: Freezer fan is not working
the fan may be jammed due to ice build up. in the first instance i would give the unit a full defrost for 48 hours then see if the fan starts after, if not the fan motor may be u/s.
Posted on Jun 02, 2007
SOURCE: lights on in frig and freezer but no compressor or fan running
It may be the thermostat
Posted on May 18, 2008
tborn6
  • 700 Answers
SOURCE: GE ELANTRA MODEL ESS 25LGMB-BB
sounds like either your fan is bad or a wire may have burned off of it. Follow the wires forthe fan back to where they make the junction with the compressor wires. when ever the compressor runs your right that the fan needs to run. If you have a meter you could ohm out the fan and see if the motor windings are indeed bad. a reading of infinite would tell the tale.go out and spend 15 or 25 o us and get a new condenser fan motor after you remove your old one and make sure that the one that oyu get is the same. and replace it. Thanks for using FixYa and don't forget to rate this answer please. Happy New Year!!!!!!
Posted on Jan 01, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Posted on Apr 22, 2009
Healeyman
  • 1198 Answers
SOURCE: Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
Posted on May 03, 2009
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
Side by side, refrigerator works, but freezer does not The freezer just started thawing everything. We can still hear something running in the refrigerator.
This is unusual. The more common set of circumstances is that the freezer works but the refrigerator doesn't. The cold air in a side-by-side is produced on the freezer side and is than transferred throughout the freezer and to the refrigerator by a fan in the freezer.
You say you hear something running in the refrigerator. This could be the freezer fan. It is located behind an access panel in the freezer. This fan should run.
You should also hear the compressor (underneath the refrigerator) running. If this doesn't run, you will not get cooling. Also, there should be a compressor fan (underneath the refrigerator close to the compressor) running. This fan removes heat from the refrigerant coils and transfers the heat to the outside. If this fan doesn't run, proper cooling cannot be obtained.
Check these things out.
Oct 20, 2009 | Refrigerators
Not sure of the model or make, but the freezer and refridgerator work and then dont work, i can freeze water but a day or two later it's thawed?
First, make sure the refrigerant coils underneath the unit are not dirty. If so, clean them off.
Second, make sure the compressor (underneath the refrigerator) is running.
Third, make sure the compressor fan (underneath the refrigerator close to the compressor) is turning. This fan should always be turning when the compressor is running. It removes heat from the refrigerant coils and transfers it to the outside.
Fourth, make certain the evaporator fan (in the freezer, likely behind an access panel) is turning.
All of these conditions must be present for proper cooling.
Oct 20, 2009 | Freezers
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Running warm. how do I recharge freon?
There are no service valves on refrigerators for charging.(They must be added).
It may not be a refrigerant problem.
Is the freezer fan motor running?
Is there a frost/ice buildup on the back wall of the freezer?
Is the compressor fan motor running?
Is the compressor Running?
These are the first steps to verify before suspecting a refrigerant leak.
Sep 05, 2009 | GE Refrigerators
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge freezer not working after power cut
If the fan motor is running at the compressor you should first replace the compressor start relay.
If the fan motor at the compressor is not running replace the defrost control.
Feb 21, 2009 | Freezers
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
