Question about Whirlpool LAB2700ML Pedestal Drawer for Duet Washers & Dryers
Whirlpool duet dryer model # GEW9200LW1 suddenly quit working. We think it is the fuses, where do we find them and how do we check to see if they are good?
    Problem Solver:
  • 12 Answers
You will need an OHM meter to check continuity. or you can jump the wires but you must replace a bad one for its a huge safety hazzard. (you can slide the 2 terminals together if you have them upsidedown from each other.
the thermal fuse is located right on top of the blower housing.
to get to it remove the lower pannel 3 1/4 inch screews you will see 2 wires going into a white plastic almost football looking peice ontop of the blower housing. it is also held in with 2 1/4 inch screews. thats the termal fuse if nothing turns on or work thats the most common problem. if you jump it and the dryer works then replace the t-fuse Part # 3392519 $20.95
Joe Johnson
Appliance Doctor
Marshalltown Iowa
Posted on Feb 07, 2009
Whirlpool duet dryer GEW9200LW1 heats
If the element was replaced, and now verified that it is not presently shorted to ground, your next diagnostic would be to to test the timer connections per the schematic lookiong for a fused contact that energizes the heater, while set to air fluff setting.
Apr 08, 2014 | Whirlpool Dryers
My whirlpoolduet dryer is on control lock how do I unlock it model # gew9200lw1
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet however, your whirlpool duet needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Whirlpool GEW9200L Electric Dryer
Whirlpool duet dryer model # GEW9200LW1, when powering up goes directly to touch up, and will not start. thermal fuse ok
Dirty moisture sensing strips? Have you tried cleaning them with windex?e03f8f0.jpg
Number 34 these measure resistance by picking up wetness from the clothes. Dryer sheets can coat these with a non penatrable film which fools the brain into thinking them clothes is dry so it moves towards the cooldown mode and shuts off with wet clothes. Clean them sensor strips real good and party on!
Oct 11, 2010 | Whirlpool Dryers
Does anyone have any idea when a Whirlpool Duet GEW9200LW1 Dryer was made? Trying to get an idea on a used one that I'm looking to purchase.
The model number tells only the year that model is introduced but the serial number tells the year and the week of production.
Sep 30, 2010 | Whirlpool GEW9200L Electric Dryer
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool duet dryer model # GEW9200LW1 suddenly quit working. We want to check the fuses but don't know where they are or how to check to see if they are working
should be located behind the kick plate on blower housing.the fus is a white fuse with a black strip down the middle and two wires going to it.you can use a set of meters that check for continuity to the fuse.or put wire ends together and wrap with electrical tape plug in dryer ad see if it works.be sure to unplug dryer before doing this.check your breaker also,make sure it hasnt tripped.
Jan 10, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool Duet Dryer - Working but no heat
i need help fixing my 5 year old dryer. whirlpool duet model GEW9200LW1. I have replaced the thermistor. I tested (with an ohm meter) the heating coil, thermal fuse, high limit thermostat, & heating element and they were all fine. I replaced the electronic control assembly and the user interface. THE DRYER STILL WONT HEAT.
Then it occurred to me that the sensor may not allow the dryer to heat if its not sensing wet. Could this be true? Have I been trouble shooting this wrong?
Help me.
Dec 16, 2007 | Whirlpool GEW9250 Electric Dryer
Washing Machines Logo
265 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
