Question about Lenovo ThinkPad R51e Notebook
After changing LCD display , Notebook don't start
I replaced the LCD , after that the notebook starts for few seconds and then stops again starts , in a recycle.
  • Lenovo Master
  • 16,181 Answers
Check the connections. Make sure that it was not a bad cable. If you had to replace the screen because of damage from a fall, there is a chance that it was more than the screen that was damaged
Posted on Nov 29, 2012
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: my notebook screen 3000 n100 goes dark after few second
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 15, 2009
A135 s2386 my laptop, the lcd image is low resolution, the external monitor is ok
Go into the Display Settings under the Control Panel and change the resolution. Some screens won't take the high resolution that's why when you replace a screen you need to make sure you're replacing it with one like you had.
Click Start/Control Panel/ Display and go to the Settings or Resolution area to change it. On some systems the Display will be under Appearance and Personalization.
Apr 06, 2012 | Toshiba Satellite A135-S2386 Notebook...
HP Pavilion DC6, Radeon Graphics card. How do I adjust contrast?
Start / Control Panel / Display / Settings / Advanced / Graphics Media Accelerator / Graphics Properties / Schemes
lots of clicks! This should get you what you want. You'll probably have to experiment with settings a little to get what is truly comfortable to you.
If this is helpful, please take a sec to rate me. Thanks!
Don
Mar 16, 2012 | HP Pavilion dv6000z Notebook
Black Screen=Bad screen or motherboard?
You have done your homework, but first! remove main battery and press power, if no change! take out one stick of ram and power up, no change remove second stick and put the first one back and power up, if no change remove hard drive and start computer to see if the logo image comes back. Now reseat the hardware back in place and start computer, if no change! the motherboard is the problem and replacement the only option.
Mar 09, 2012 | Dell Inspiron B130 Notebook
Forgotten how to turn it on. It seems to be set on timer. Oops
push stop button for a few seconds until it beeps or the readout changes. unplug,,,,,plug back in....push "Select" or "menu" button depending on which machine you have....push again and again until the program you want is on the display or readout. Then push the "start" button ....Don't push any timer buttons or arrows!
Dec 04, 2011 | Kitchen Appliances - Others
My hp dv600 when powered up looks normal but if i give it a few seconds the screen goes black and wont come back i shined a light and i do have picture but no light maybe ballast?
alejandro,
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Very similar to the Fluorescent lamps, (Bulbs), used in homes and businesses, but on a MUCH smaller scale.
HP Pavilion dv6000z series Notebook PC, is a general series designation. The EXACT model number is on the bottom of the laptop in a white Service Tag.
The HP Pavilion dv6000z series of Notebook PC's used either an LED or CCFL type of Backlighting.
Depends on which model it is.
http://www.screentekinc.com/backlight-ccfl-led-explained.shtml
As stated in the above information a Backlight is mounted in the back, or on the side of the LCD screen.
The LCD screen is composed of layers. These layers are held together by a metal frame which emulates a picture frame. If the Backlight is a side unit it will be held in place next to the layers, and inside the metal frame.
[Which means the LCD screen's metal frame, (LCD Panel Frame), needs to be opened on one side.
This will leave the layers which compose the LCD screen loose. The layers MUST be held in the proper placing when changing out the Backlight. Not an easy job to accomplish]
An Inverter is used to change the power coming from the laptop, to be used by the LCD screen, and Backlight.
90 percent of the time the problem is the Inverter.
The Inverter for the Pavilion dv6000z series of Notebook PC's is located inside the Display Assembly.
The Display Assembly is the
1) Display Enclosure Cover, (Plastic top of laptop),
2) LCD screen,
3) LCD Panel Frame, (Metal frame around LCD screen),
4) Display Bezel, (Thin plastic frame which surrounds the LCD screen in the front)
5) Camera Module
6) Inverter
7) Display Enclosure Cover Hinges (2)
8) Display Enclosure Cover Hinge Covers (2)
9) Wireless Antenna Transceivers and Antenna Cables
10) Microphone receivers and cables
11) Various mounting screws
[The Top Cover for a Pavilion dv6000z series Notebook PC is essentially the Palm Rest. The cover under the Keyboard]
With the Display Bezel removed the Inverter is located at the bottom.
(Display Assembly removed from laptop first)
HP Support > Pavilion dv6000z Notebook PC series> Manuals>Service Manual>
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3224052&
One example of an Inverter for an HP Pavilion dv6000z series Notebook PC,
http://www.amazon.com/DV6000-DV9000-V6000-INVERTER-AS0231721C1/dp/B00480MXUS
Please post additional questions in a Comment.
Regards,
joecoolvette
Jun 11, 2011 | HP Pavilion dv6000z Notebook
My Dell Latitude D6000 just stopped. One night it was working just fine. I turned it off, went to bed. The next day, it refused to start up. It almost started up today, but shut off after a few seconds. I...
If by wont start up you mean the screen shows nothing and their are no errors you the motherboard on it is probably damaged beyond repair, and the laptop will need to be replaced. However, if you have an error about boot devices you may wish to look at this tip
May 13, 2011 | Dell Latitude D600 Notebook
HI, i have sony vaio laptop. few months ago i face the problem that my computer LCD light. after starting 2 or 3 times it show the screen. it is running every time. i can see dim screen but after 3 or 4...
In your situation, you have the possibility of several different problems.
1. Your "Screen Inverter" is failing.
2. Your screen "LCD Panel" is failing
3. The "Video Controller Chip" soldered permanently to your motherboard is failing.
The first step in troubleshooting these problems would be to take your laptop to a friend's house who is using a desktop computer with a separate external monitor. Hook your laptop up to the external monitor and see if it displays normally on that monitor. If it does, you merely need to replace both the Screen Inverter and LCD Panel of your laptop and you'll be fine.
If, however, your laptop will not display on an exterior monitor, it means that your video controller on your motherboard has failed and you'll have to either get a new motherboard installed or consider replacing your laptop.
I'll be rooting for # 1 or 2.
Kind Regards,
Selk
Apr 29, 2011 | Sony VAIO Notebook
HP Pavilion, Screen working, but extremely dark!
As per your description, I find that the issue is with the LCD Backlight which is also called as LCD Inverter which lights up the LCD to show us the Display on the LCD Display.
If this Backlight is gone bad, you will be barely able to see the Display on the LCD.
Coming to the Noise you had mentioned above can be from the Cooling fans of the Notebook which will be spinning at high speed when the Notebook starts and will reduce gradually after few minutes.
I recommend you to try cleaning the Cooling fan vents using any Vacuum Cleaner or Air Blower.
I recommend you to contact any nearest HP Authorized Service Center and get the LCD Backlight replaced.
Hope this helps....
Jul 21, 2008 | HP Pavilion dv6000z Notebook
No light is on but fans on
I would bet your system has been overheating - that's why it kept shutting off. Now it may have overheated and killed your CPU or mainboard. These laptops require quite a bit of disassembly to get at the CPU. You will probably have to take it to a repair shop for further work.
Oct 06, 2007 | HP Business Notebook NX9110 Notebook
Open Questions:
can you please help ms drunel broussard who just received custody of 2 of her abused grandchildren in nov 2017 have a great xmas not having a home with furnishings..she no longer have stable housing ms drunels daughter and boyfriend had been abusing her children..shes a great person with such agood heart and shes struggling to keep the kids..while in moms care the kids was sleeping on the ..have very min clothing..ms drunel took her car notes monies to get the kids basic clothing and hygiene needs..shes help so many7 ppl and always been an strong person..not knowing where they would lay their heads at..i watch her go and visit ,pray for ppl in the hospital..when you ask herhow is things going shell say all will be well..but today i seen her breakdown and crying..letting the kids know she might have to let them go to foster care because she cant provide them with a stable place..to know her is to truly love her..and to see her not be able to care for them the way she cared for hewr children and other ppl children is taking a toll on her.but she keeps smiling..she really need help and an agency in jax fl where she lives told her to give them up or go to a shelter...she replied ok ..and left..doors is not opening and due to the NATURE OF THE abuse..and physical abuse these babies been through she said no..they have nothing i mean nothing for xmas...less alone shes facing losing her means of transportation to get them to and from school...counseling ...and dr.appt...PLEASE PLEASE I BEG OF YOU HELP THIS FAMILY...THANK YOU FOR YOUR TIME
Dec 14, 2017 | The Computers & Internet
See all Lenovo ThinkPad R51e Notebook Questions
Lenovo ThinkPad R51e Notebook Logo
26 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
