Question about Procom SSU320RHN-GB Heater
I have a 5301. Connected last year, worked fine. Installed new batteries, connects and beeps, but fireplace won't light. All controls are in correct position.
  • 72 Answers
I know it seems obvious, but sometimes over the summer people shut off their pilot light, and when relighting forget to move the pilot knob back to the "on" position after the pilot is going - check this first.
Next, you can slide the switch on the Skytech 5301 receiver from "remote" to "on" and verify that it lights the burner. If it does, you may need to re-sync the remote to the receiver. If it does not, check to make sure your wires are nice and tight on the TH & TP/TH connections of the valve.
If you are still having trouble, Skytech has a toll-free hotline for tech support on the 5301. It is: 1-888-672-8929 8am-5pm EST.
Posted on Nov 30, 2012
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
Pilot light 5301
The Skytech 5301 does not control your pilot light. That is a function of your fireplace's valve. Complete instructions for lighting your pilot can be found in the owner's manual of your fireplace, or at the brand's website.
The 5301 should not need to be reset in any way. Once your pilot is re-lit it will operate normally.
If you need a new copy of the 5301 manual, it can be found at the bottom of the product page here: Skytech 5301 fireplace remote.
Mar 16, 2013 | Skytech 5301 Fireplace Remote Touch Screen...
Ambient remote control 5884 won't turn fireplace on and off
  • Make sure your valve is in the "on" position and not "pilot".
  • Install fresh batteries in both remote and receiver (remotes are finicky about good batteries.
  • Ensure the switch on your receiver is in the "remote" position.
  • Follow manual to re-sync handheld to receiver if necessary.
  • A burner not lighting could also be the fault of the appliance (bad thermopile). Check this too, and replace if needed.
  • Replace remote if necessary: Universal Fireplace Remotes
Dec 28, 2012 | Ambient Tech. Rcmt Manual Fireplace Remote...
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Nov 08, 2012 | Skytech 1001-A Fireplace Remote Control...
My skytech remote is blank I have changed the batteries what else can I try?
The Skytech 5301 Fireplace Remote's touch screen should never be blank, especially if it has fresh batteries (assuming they are installed in the correct orientation).
Skytech offers a generous warranty, you should contact their support team at 1-888-672-8929 to request service on your remote.
Sep 14, 2011 | Skytech 5301 Black On/Off Wireless...
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
It seems to have no power the led light doesn't come on. its brand new, but I havent used it in about five years
Are you using battery or AC adapter for power?
Most pedals won't allow you to use both. Check that there is no battery installed if you're going to plug it in. If you are using a battery, Some pedals won't light an LED on battery power.
If problem persists, your pedal may be DOA
May 04, 2011 | Boss Mt 2 Metal Zone Effects Pedal
Receiver was beeping all the time. I changed batteries in receiver, and now remote does not control fireplace. Remote appears to be working fine. If I move switch to on instead of remote on receiver, it...
If you changed the batteries in the receiver (the black box in the fireplace). You should also change the 2-batteries in the hand-held remote. This may sound stupid, but it's not ... be sure all the batteries in the receiver (black box) are all facing the proper direction. Believe me, it's easy to get one turned the wrong direction. Also, make sure that the slide switch is in fact in the remote position. It can be finicky at times. Also, check to make sure that the two wires are still connected firmly at the gas fireplace Control Valve and in the receiver.
  • Now, if all of that doesn't solve your problem, the receiver may have lost it's code..
When matching security codes, be sure slide button on the receiver is in the REMOTE position; the code will NOT "LEARN" if the slide switch
is in the ON or OFF position. Program the remote receiver to LEARN a new security code by pushing in the LEARN button on the top of the
remote receiver and then pressing the MODE button on the transmitter. A change in the beeping pattern, at the receiver, indicates the
transmitter's code has been programmed into the receiver.
There's a lot to check out and do, but that's how you trouble shoot these remotes.
Feb 03, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
My remote won't control the fireplace. Do you have to program it
Normally, it comes programed. Before trying to reprogram it ...First, be sure you have the leads from the black receiver box connected to the proper terminals on the control valve of your gas fireplace. Secondly, be sure ALL the batteries are installed properly (i.e. facing the right direction). Do you get a beep when you press the Mode button on the hand held remote? If you do, the problem is some where else.
If you gas fireplace has a rocker switch in the control compartment that was used to turn the burner on and off ... Is it a 2 position switch or a 3 position switch? If it's a 2 position switch, be sure it's in the ON position. If it's a 3 position switch, it should be in the middle position. Is the gas control valve knob turned from Pilot to the ON position? Is your Pilot Light burning? It has to be for the remote control to work.
To test the whether or not the remote is connected properly, push the slide switch on the front of the black receiver box to the ON position. If you pilot is burning and the control knob for the burner is in the ON position, the burner should then light. If it doesn't then I suspect the wiring from the black receiver box to the control valve is not connected to the proper terminals. Or a rocker switch is in the wrong position. If all this fails contact SkyTech Technical Service @ 888-672-8929.
Jan 10, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
Procom SSU320RHN-GB Heater Logo
347 people viewed this question
Top Procom Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
